sound of a flickering neon
I would like to create the sound of a flickering neon using the buzzer Piezo. Does anyone know if that is even possible ? If yes, any idea on how to do so?
Any help appreciated, Thank you
m
Frequency of 60hz, and use a random number generator to determine lengths of the tone and silence between tones.
Tell us more. Do you want to turn on a led display, let it blink a few times and make a neon-switching-on sound ? Do you have an example of the sound ? The best sounds for the Arduino are with a Sound/Wave/MP3-shield and the sounds could be on a SD card. With only the Arduino it might not be possible. Read this, http://playground.arduino.cc/Main/ArduinoSynth And have a look at the Mozzi library.
Works great Focalist! Thank you
Erdin, thanks for the reply. Yes, I would like the Led to blink when the neon sound is on. The sound would be something like this http://www.hark.com/clips/lqbtjdvvyk-neon-tube-flickers
I will look into the Mozzi library for sure. I didn't know you could use real sounds with Arduino, I am not very advanced at using it but I will look into it.
I was able to create a random sound based on Focalist advice, but if I can use a more complex sound that would be better.
Thanks again!
You might take a look at toneAC(), http://playground.arduino.cc/Code/ToneAC
It has some kind of volume control, allowing to make more sounds.
It can do a little more than the standard tone(), but it is not as sophisticated as Mozzi.
I can’t download the neon sound, so I can’t analyze the frequency !
