So, I'm trying to have my Arduino + sound sensor manipulate LEDs and the code I'm working with doesn't quite do what I need and I'm a bit out of my element here.
The goal is to have the lights glow as someone speaks into the sensor.
Right now, when the sound sensor receives sound it sends either ON or OFF making the LED's blink violently and I'm trying to have the lights dim more gradually.
Any suggestions?
#define LEDstrip 9
pinMode(7,INPUT); //SIG of the Parallax Sound Impact Sensor connected to Digital Pin 7
pinMode(LEDstrip, OUTPUT);
//this function will make the LED dim once the Parallax Sound Impact Sensor sends a 1 signal, and then return to it’s original brightness.
boolean soundstate = digitalRead(7);
if (soundstate == 1) {
analogWrite(LEDstrip, 255);
delay(10);
else{
analogWrite(LEDstrip,0);
How are Ebay links useless? You implied that they need to provide what sensor they have and the link leads to the details/description of the exact sensor.
With that being said..
natewhatever:
Any suggestions?
It looks like the sensor you have can only detect sound or no sound. It can't differentiate between "quiet" sound or "loud" sound. There might be a round about way to do it within your code, but it might get a little complicated. For example, if there is a continuous sound, set the LEDs to start at a "dim" color and then iterate through colors that are increasingly brighter. If there is no sound after a set amount of time, then have them go off. Not saying this is guaranteed to work, but it might be worth a try.
I know this post is pretty old, but I just thought I'd offer some help (sorry it wasn't much).
