Sound Sensor / Noise Meter with Electret Mic
This is a sound sensor that will make red LEDs light up when the noise level reaches a certain threshold. It could be useful for a classroom. It will respond to talking from across the room.
It was made using an electret microphone, which is cheap and surprisingly sensitive. Also, I used an opamp to amplify the microphone signal, it’s available for five dollars at this site. http://www.sparkfun.com/commerce/product_info.php?products_id=8704
There is a special circuit to make the microphone work. You can look at the first circuit drawing on this site: http://www.epanorama.net/circuits/microphone_powering.html or my drawing below.
                                                  • 5v
                                                    2k Resistor
                                                    0 - - - - - - 10 uF capacitor - - - - - 0 - - - - - - to Op-Amp “in”
                                                    +mic 10 k Resistor
  • mic |
        • Ground
Then op amp “out” goes to an arduino analog pin, pin 4 with the code below.
The sensitivity of the mic can be adjusted by turning the potentiometer on the op amp with a screwdriver.
//SOUND MONITOR for the classroom
int sensorPin = 4;    //Microphone Sensor Pin
int YellowLED = 1;
int RedLED = 4;
int sensorValue = 0;
  pinMode(YellowLED, OUTPUT);
 pinMode(RedLED, OUTPUT);
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
 Serial.println(sensorValue);
 /* If you feel that the sensor values on the serial monitor
 are going by too quickly for you to read, you can make it
 so that the values only show up on the serial monitor
 if you make a noise.  You can replace
  with:
 if (sensorValue < 509){
  digitalWrite(YellowLED, HIGH);  //Yellow is always on.
  if (sensorValue<509){  //The 'silence' sensor value is 509-511
    digitalWrite(RedLED, HIGH);
    delay(2000);            // The red LEDs stay on for 2 seconds
    digitalWrite(RedLED, LOW);
