Sound Sensor not working
I've added a sound sensor and LED that lights up when it hears a sound. I've tried the sound sensor code only and it works but when i add the code to the others, it stops working.
#include <dht.h>
#include <Servo.h>
#define DHT11_PIN 2
#define DHTTYPE DHT11
Servo servo;
dht DHT;
//Servo
int moto = 8;
int angle = 0;
int tempe = 40;
//Sound
int soundpin=6;
int ledpin=7;
  //Sound
  pinMode(ledpin,OUTPUT);
  pinMode(soundpin,INPUT);
  servo.attach(moto);
  //Sound Sensor
  int statusSensor = digitalRead(soundpin);
  if(statusSensor == 1)
    digitalWrite(ledpin,HIGH);
  else{
    digitalWrite(ledpin,LOW);
  //Humidity Sensor
  int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
  delay(2000);
  //Servo Motor
  if(DHT.temperature >= tempe)
    for(angle = 10; angle < 180; angle++)
      servo.write(angle);
      delay(10);
What are the spec of the sound sensor ?
it doesn't say on the set but this is the red one with 4 pins.
Try turning on some kind of sound and measureing the digital input pin with a voltmeter.
You may have to set the adjustable pot to get a 1 one out of it. You could also
read it with an adc using analog input should go from 0 to 1023. Use Serial.println statements.
You have a 2 second delay! what if the sound happens during that time (HINT : NOTHING).
Does your sensor have a sensitivity knob? You may need to tune the sensitivity.
Does your sensor have an indicator light? If not you can use this sketch to test the output:
const int soundpin=6;
const int ledpin=7; // or use LED_BUILTIN
  pinMode(soundpin, INPUT);
  pinMode(ledpin, OUTPUT);
  digitalWrite(ledpin, digitalRead(soundpin));
