sound sensor
I have a problem to do a sound sensor circuit that measures the sound and turn some LEDs on depending on the strength of the sound. if I tried to combine the two circuits shown down, it would work porperly.?!
First 2 images are not allowed to be viewed...
This is the circuit:-
Looks OK but without values you can’t be sure. I would worry about the input to that op amp.
I thought you wanted to measure sound........... That circuit has a photodiode as it's input.
regards
Allan
Yup, I want to change the photodiode to make it measure the sound.
Well that circut certainly won't do it!
Whast sort a microphone are you intending tho use? how loud are the sounds you want to switch at?
Over what frequency band do you want to run?
regards
Allan
Barahim:
Fantastic, you post a circuit and ask if it will work and then say you are going to change it and the circuit is not the one you want to use at all.
I had assumed that the 555 timer was generating the tone you wanted to measure but no. What a ****ing time waster you are.
