Sound sesnor turns on after LED turns off
Hi.
I bought this sound sensor from SparkFun Sound Detector - SEN-12642 - SparkFun Electronics
I hooked up like this:
Sensor Arduino
GND -> GND
VCC -> 5V
GATE -> Digital Pin 7
Gate returns 0 or 1, just like simple push button - 0 when sound does not reach treshold and 1 if it does. Everything worked as espected, but I wanted to add LED on my board. So I attached it on digital pin 10 and GND. And i programmed of course without delay function to escape from additional problems.
Problem: Now everytime when LED turns off, sound detector somehow detects sound:
Here is my code:
// Sound sensor
const int sensorPin = 7;
int clapCount = 0;
int sensorState = 0;
int lastSensorState = 0;
unsigned long prevClap = 0;
unsigned long currentClap;
unsigned long timeBetweenClaps = 0;
// LED
const int ledPin =  10;
int ledState = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
  pinMode(sensorPin, INPUT);
    pinMode(ledPin, OUTPUT);
  // LED
  if (currentMillis - previousMillis >= interval) {
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
  // Sound sensor
  sensorState = digitalRead(sensorPin);
  currentClap = millis();
  if (sensorState != lastSensorState) {
    if (sensorState == HIGH) { // If hands are clapped
      timeBetweenClaps = currentClap - prevClap;
      clapCount++;
      Serial.print("CLAP: ");
      Serial.println(clapCount);
      Serial.println(timeBetweenClaps);
      prevClap = currentClap;
  lastSensorState = sensorState;
Here is what i get in serial monitor even if there is a silence in room:
CLAP: 1
2000
CLAP: 2
2000
CLAP: 3
2000
CLAP: 4
2000
Can anyone please help? What could be the problem? Thanks.
UPDATE:
I changed voltage from 5V to 3.3 (Specs say: 3.5 and 5.5 Volts. 5 Volts is ideal) and everything works.
Could this mean there is some noise or what after the LED turns off?
Please explain this to me. I am just curious.
Your code looks fine to me..
Did you use a resistor somewhere in that circuit ?
hi,
have you tried to lower the gain according to the link you provided.
It says the sensor can be very sensitive.
https://learn.sparkfun.com/tutorials/sound-detector-hookup-guide?_ga=1.258358218.1132688230.1429269663
