So I have a sound sensor and it works fine...except that analog signals aren't affected by sound. ie: Room is quiet, the led of the sensor isn't receiving sound. If I blast music the sensor led lights up, but the analog signal stays the same (240~250 ish). Any ideas on how to get it working? Specifications and code are below.
int Led = 12 ;
int Sound = A0;
int val = 0;
void setup ()
pinMode (Led, OUTPUT) ;
pinMode (Sound, INPUT) ;
void loop ()
val = analogRead(Sound);
Serial.println(val);
delay(100);
Sound sensor: KY-038 (the one with 4 pins)
Board: Arduino UNO
If I missed any info just tell me; thanks in advance
In looking at the schematic the pot does nothing but set the level for the comparator. That sets the threshold voltage for the digital output. It has no effect on the analog output. The analog output is the sound output from the electret microphone. There is no amplification nor buffering. The levels will be in the millivolt range, not suitable to be read with the analog input. If you want to use the microphone analog output you will need to purchase or make a pre-amplifier. There are many circuits available on line. This is where I found the schematic:http://arduinolearning.com/wp-content/uploads/2018/07/KY_038_Microphone_sound_sensor_module.png
