Soundboard that can play more than one sound
I am trying to get a soundboard that can play more than one sound at once. Currently, I am using Adafruit Audio FX Sound Board + 2x2W Amp - WAV/OGG Trigger - 2MB : ID 2210 : $24.95 : Adafruit Industries, Unique & fun DIY electronics and kits and would like to use something similar. All I need is for it to be able to play more than one preloaded sound simultaneously. Any soundboard suggestions would be much appreciated.
Ozymandeus:
To quote the description of the board you linked to: "The sound board is designed to be simple: it does not have polyphonic ability".
You need a different board.
Paul
Simultaneously is impossible with any audio shield that I know of. They aren't programmed to do that and you don't have access to the firmware programed-into the chip.
You could use two audio shields and make a little passive mixer with a couple of resistors or an active mixer with an op-amp. (Analog mixers are built-around summing amplifiers.)
Or you could go "back to the drawing board" and use a Raspberry Pi or something like that. Mixing digitally is straightforward (as long as you can get to the audio stream). You simply sum the audio streams sample-by-sample. And, usually you scale-down to avoid clipping so it's more averaging than summing.
