Hello All,
I have a program to control an RC car. The code compiles and uploads fine. It also prints out the ip address in the serial monitor. When i type the ip address into my browser i get an error that says the ip address can not be reached. Below is my code.
Thank you
Alex
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
// Define variables with the pin values
const int DRIVE_MOTOR_POWER = D2;
const int DRIVE_MOTOR_DIRECTION = D4;
const int STEER_MOTOR_POWER = D1;
const int STEER_MOTOR_DIRECTION = D3;
// drivePower sets how fast the car goes // Can be set between 0 and 1023 (although car problaly wont move if values are too low)
int drivePower = 1023;
// driveDirection sets what direction the car drives // If the car is moving backwards when you press the forward button, change this to LOW
uint8_t driveDirection = HIGH;
// steeringPower sets how fast the car turns // Can be set between 0 and 1023 (again, car probably won't steer if the value is too low)
int steeringPower = 1023;
// steerDirection sets what direction the car steers // If the car is steering right when you press the left button, change this to LOW
uint8_t steerDirection = HIGH;
const char* ssid = "wifi_username";
const char* password = "wifi_password";
ESP8266WebServer server(80);
void handleRoot() {
server.send(200, "text/plain", String("Hello from esp8266!"));
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void){
pinMode(DRIVE_MOTOR_POWER, OUTPUT);
pinMode(DRIVE_MOTOR_DIRECTION, OUTPUT);
pinMode(STEER_MOTOR_POWER, OUTPUT);
pinMode(STEER_MOTOR_DIRECTION, OUTPUT);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", handleRoot);
server.on("/forward", {
Serial.println("forward");
analogWrite(DRIVE_MOTOR_POWER, drivePower);
digitalWrite(DRIVE_MOTOR_DIRECTION, driveDirection);
server.send(200, "text/plain", "forward");
server.on("/driveStop", {
Serial.println("driveStop");
analogWrite(DRIVE_MOTOR_POWER, 0);
server.send(200, "text/plain", "driveStop");
server.on("/back", {
Serial.println("back");
digitalWrite(DRIVE_MOTOR_DIRECTION, !driveDirection);
server.send(200, "text/plain", "back");
server.on("/right", {
Serial.println("right");
analogWrite(STEER_MOTOR_POWER, steeringPower);
digitalWrite(STEER_MOTOR_DIRECTION, steerDirection);
server.send(200, "text/plain", "right");
server.on("/left", {
Serial.println("left");
digitalWrite(STEER_MOTOR_DIRECTION, !steerDirection);
server.send(200, "text/plain", "left");
server.on("/steerStop", {
Serial.println("steerStop");
analogWrite(STEER_MOTOR_POWER, 0);
server.send(200, "text/plain", "steerStop");
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP Server Started");
void loop(void){
server.handleClient();
