I tried figuring this out a few weeks ago, but because I couldn't find the example that used this spacing method I couldn't post an example that used it.
I want to know what spacing method is used here. if you copy this code to the arduino and backspace the place before PR it will back space 5 or so places. Similar to how the tab key works in microsoft. If you hit tab after you backspace it only spaces two places though.
I know you can change the spacing of tab in advanced settings, but when you hit backspace after tab it only goes back one, which has led me to believe this spacing method might not be tab.
Can someone tell me what is used?
while (Pass.available() > 0) {
PR = Pass.read();
