Spark fun Rotary Encoder and MEGA Arduino
I have tried commenting out code and still not working, verified that the encoder is wired up correctly. 2 days later, I need help. if I could get a pointer to a libe that works with the Spark fun RGB encoder that would be great
// LimitedRotator.ino - Example for the RotaryEncoder library.
// This class is implemented for use with the Arduino environment.
// Copyright (c) by Matthias Hertel, htt mathertel.de
// This work is licensed u
// More information on: htt Arduino Projects
// 26.03.2017 created by Matthias Hertel
// 06.02.2021 conditions and settings added for ESP8266
// This example checks the state of the rotary encoder in the loop() function.
// The current position is printed on output when changed.
// In addition to the SimplePollRotator example here the range of the rotator is limited to the range 0 - 16 and only incremental steps of 2 are realized.
// To implement this limit the boundaries are checked and eventually the current position is adjusted.
// The internal (physical) position of the rotary encoder library remains by stepping with the increment 1
// so the the logical position is calculated by applying the ROTARYSTEPS factor.
// Hardware setup:
// Attach a rotary encoder with output pins to A2 and A3.
// The common contact should be attached to ground.
#include <Arduino.h>
#include <RotaryEncoder.h>
#if defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_NANO_EVERY)
// Example for Arduino UNO with input signals on pin 2 and 3
#define PIN_IN1 2
#define PIN_IN2 3
#elif defined(ESP8266)
// Example for ESP8266 NodeMCU with input signals on pin D5 and D6
#define PIN_IN1 D5
#define PIN_IN2 D6
#endif
#define ROTARYSTEPS 2
#define ROTARYMIN 0
#define ROTARYMAX 16
// Setup a RotaryEncoder with 4 steps per latch for the 2 signal input pins:
// RotaryEncoder encoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::FOUR3);
// Setup a RotaryEncoder with 2 steps per latch for the 2 signal input pins:
RotaryEncoder encoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::TWO03);
// Last known rotary position.
int lastPos = -1;
while (! Serial);
Serial.println("LimitedRotator example for the RotaryEncoder library.");
encoder.setPosition(10 / ROTARYSTEPS); // start with the value of 10.
} // setup()
// Read the current position of the encoder and print out when changed.
encoder.tick();
// get the current physical position and calc the logical position
int newPos = encoder.getPosition() * ROTARYSTEPS;
if (newPos < ROTARYMIN) {
encoder.setPosition(ROTARYMIN / ROTARYSTEPS);
newPos = ROTARYMIN;
} else if (newPos > ROTARYMAX) {
encoder.setPosition(ROTARYMAX / ROTARYSTEPS);
newPos = ROTARYMAX;
} // if
if (lastPos != newPos) {
Serial.print(newPos);
lastPos = newPos;
} // if
} // loop ()
// The End
You should RE-edit your posting to show your code by using code-tags
Click the pencil-icon on your post.
delete all the lines of code.
Then
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
the NewEncoder-library from user gfvalvo works very reliable
general hints:
  • You should take away any work from your potential users that you can do on your own. This means provide a download-link of the datasheet of all devices that you are using.
  • write the exact type of microcontroller you are using.
  • describe the behaviour of your code
best regards Stefan
