Sparkfun APDS 9960 "Reset" Question
I am new to Arduino and coding in general. I have done a few tutorials and easy projects and I am now starting something of my own from example code.
Trying to achieve a proximity sensor that will detect when someone's glass is close, then trigger a pump to fill the glass.
I am using an Arduino Uno and a Sparkfun APDS 9960. I have not gotten to the actual output to the pump yet, but the serial monitor is behaving the way it should. My issue happens when I power the Uno down.
If I unplug the Uno and then plug it back in, the serial monitor stops reading my proximity values. Even when I resend my code it doesn't work anymore. BUT, if I send the example code from the APDS 9960 library "Proximity Sensor", and THEN resend my code, I can get the sensor to behave normally again.
Could anyone shed some light on why this is happening? I have included both my code and the Proximity Sensor Example.
I have tried replacing the sensor and the Uno to see if there were hardware issues/damage, and got the same repeatable results each time.
My Code:
#include <Arduino_APDS9960.h>
#include <Adafruit_APDS9960.h>
#include <Wire.h>
#include <SparkFun_APDS9960.h>
// Constants won't change:
const int sensorData = 2;     //APDS Sensor input
const int pumpControl = 9;    // the pin that the pump is attached to
// Variables will change:
int proximityValue = 255;  // Proximity data between 0 and 255
  // initialize the button pin as a input:
  pinMode(sensorData, INPUT_PULLUP);
  // initialize the LED as an output:
  // initialize serial communication:
  pinMode(pumpControl, OUTPUT);
  // Initialize Serial port
  Serial.println(F("---------------------------------------"));
  Serial.println(F("SparkFun APDS-9960 - Proximity Pump"));
  // read the sensor data input pin:
  if (APDS.proximityAvailable()) {
    // read the proximity
    // - 0   => close
    // - 255 => far
    // - -1  => error
    int proximityValue = APDS.readProximity();
    // print value to the Serial Monitor
    Serial.println(proximityValue);
  // compare the buttonState to its previous state
  if (proximityValue <= 100) {
    // if the sensor reads something close
    (pumpControl == HIGH);
      // if the current state is HIGH then the pump turns on
      Serial.println("on");
    else {
      // if the current state is LOW then the pump stays off
      (pumpControl == LOW);
      Serial.println("off");
  // wait a bit before reading again
  delay(200);
  APDS9960 - Proximity Sensor
  This example reads proximity data from the on-board APDS9960 sensor of the
  Nano 33 BLE Sense and prints the proximity value to the Serial Monitor
  every 100ms.
  The circuit:
  - Arduino Nano 33 BLE Sense
  This example code is in the public domain.
  while (!Serial);
  if (!APDS.begin()) {
    Serial.println("Error initializing APDS9960 sensor!");
  // check if a proximity reading is available
    // - 0   => close
    // - 255 => far
    // - -1  => error
    int proximity = APDS.readProximity();
    Serial.println(proximity);
  delay(100);
Thank you for your time.
The example code has this in it:
APDS.begin()
Yours doesn't. I don't know anything about the hardware you're using, but I suspect that is a problem.
That was it! Solved my issue. Thanks so much.
