sparkfun button pad project, 2 arduinos
hi, havent posted in a while, nut i'm back again to try and get this button pad working! it's been lying in my room for over a year, and i posted before for help with less then great results, but hopefully we can get it up and running.
So i have the sparkfun button pad ( 4 x 4 buttons ) it's all hooked up and ready to go. and i'm using an arduino to control half of it. it sounds weird but im using 2 arduinos to control it because i have john ryan's dual core arduino board so i'm actually using one arduino to control each side of the button pad, and one of the arduino's also control the ground.
the way i have everything setup is:
i have the button pad led's rgb output from the sparkfun pcb hooked up to resistors, then connected to the arduino.
like i said, it will only control half of the button pad, but that's all i need for now...
the problem is, no matter how i setup my code, if i try to get one button on, and the rest off, other buttons turn on! the lights won't stay off on the buttons, it seems like the color "bleeds" off to the other button in that row. and i'm running it normally, one column of ground on, the rest off, one at a time, so i can control each button. ill post my code so you can see for yourself:
code:
int time = 1;
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(4, OUTPUT);
pinMode(2, OUTPUT);
void loop(){
 digitalWrite(8, LOW);
 analogWrite(10, 255); // turns the blue on
 delay(time);
 digitalWrite(8, HIGH);
 analogWrite(10, 0); // turns the blue off
 delay(time);
 digitalWrite(7, LOW);
 delay(time);
 digitalWrite(7, HIGH);
 delay(time);
 digitalWrite(4, LOW);
 delay(time);
 digitalWrite(4, HIGH);
 delay(time);
 digitalWrite(2, LOW);
 delay(time);
 digitalWrite(2, HIGH);
this code controls the grounds so they are connected one at a time. and just as a test i turn one color on the see it work. the above effect works when the "time" integer is set to 100 ( runs the refresh rate very slowly ) but when i speed it up the "time" integer to 1, the lights on the button freak out and the button i told to turn on and the button before it both turn on and make a dimming effect. the button i want to work dimms on, while the button next to it dimms off... not sure why it isint working right.
if your not sure what i'm talking`about think of this:
how would you make the sparkfun button pad work with the arduino? ( considering you only make half of the button pad light up. )
and just as extra info, i'm using 2 arduinos because i want pwm control of the lights, i dont want just on or off, that's why its more complicated... sure just having on or off could produce, what, 7 colors? i'd rather have the whole color spectrum at my disposal.
thanks for any help, and i'll try to post the results of the above sketch in the next couple of minutes.
edit: i took a quick video with my phone:
IGNORE THE BOTTEM ROW THAT IS CONSTANTLY ON, focus on the two buttons that are flickering... they shouldn't do that, one is just sapposed be on, the other off
will be processing for a few mins...
Could you supply a schematic of how you have it wired?
here is a link to the sparkfun button pad schematic, it's right under all the info.
and after that, theres not much to draw to schematic, i'll explian it, but if it's still unclear, ill go ahead and draw and paste a schematic of what i did.
To put it into words, i didnt bother to hook up all the button functions of the pad yet, because i need the lights to work before im gonna even start with the buttons.
the lights, all the red green blue connections are just run from the above schematic , to resistors, then to the arduino's pwm pins (11,10,9,and 6,5,3). then all the grounds i connected to arduino's digital pins ( 2, 4, 7, 8 ) with no resistors because i already connected resistors to each rows color input.
simply... arduino's pwm pins are wired to resistors, that are wired to the button pad. all the grounds are then conected to arduino pins, listed above...
all the code in the above post is mostly just connecting one ground at a time
it seemed too simple to make a schematic but if your still unclear, let me know and ill make a quick schematic...
thanks
i hate to be that guy, but cmon, nobody knows whats wrong? i'm pretty sure ( 80 % ) that the way i have it set up, it simply impossible to get the buttona pad working, but i just want a confirmation. just look it over quick and say "becuase you do this, the project can't work" so i can atleast start working on fixing it. this thing has been sitting in my room for almost A YEAR! it's pretty annoying to have something lying around ,reminding you you can't finish working on it because your short of experience...
don't just look this post over and click away, see if you can help me, and if it's unclear enogh, tell me and i'll do whatever you need to clarify it for you so you can help me.
thanks for anyone who cared to even read this...
