Sparkfun canbus shield with LSM6DS33 dual SPI problem
Hello fellow arduino users! I have a question regarding using the Sparkfun Canbus shield in conjunction with the LSM6DS33 sensor on a dual SPI configuration. I have managed to get theese two to initialize but after reviewing the data it seems that the accelerometer is sending wrong readings... I am guessing the SPI devices mess with each other. Any idea on how to fix this? I am using an UNO R3 and here is the code:
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#include <Canbus.h>
#include <TinyGPS++.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
#include <Keypad.h>
#include <Adafruit_LSM6DS33.h>
#define LSM_CS 9
#define LSM_SCK 13
#define LSM_MISO 12
#define LSM_MOSI 11
Adafruit_LSM6DS33 lsm6ds33;
TinyGPSPlus gps;
SoftwareSerial ss(3,2);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad membrane = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
String s;
int IATMP;
float MAF;
int VSPD;
int RPM;
float MAF2=0.0;
float DeltaMAF=0.0;
char iatbuffer[64];
char mafbuffer[64];
char vspdbuffer[64];
char rpmbuffer[64];
unsigned long currtime;
unsigned long deltatime;
const unsigned char UBLOX_INIT[] PROGMEM={
0xB5,0x62,0x06,0x08,0x06,0x00,0xC8,0x00,0x01,0x00,0x01,0x00,0xDE,0x6A
//********************************Setup Loop*********************************//
  ss.begin(9600);
  //Initialize Serial communication for debugging
  while (!Serial){
    delay(10); }
  for(unsigned int i=0;i<sizeof(UBLOX_INIT);i++){
    ss.write(pgm_read_byte(UBLOX_INIT+i));
  if(Canbus.init(CANSPEED_500))  /* Initialize MCP2515 CAN controller at the specified speed */
    Serial.println(F("CAN Init Ok"));
    delay(1500);
    Serial.println(F("Can't init CAN"));
    return;
if (!lsm6ds33.begin_SPI(LSM_CS, LSM_SCK, LSM_MISO, LSM_MOSI)) {
    Serial.println(F("Failed to find LSM6DS33 chip"));
    while (1) {
      delay(10);
Serial.println(F("LSM6DS33 Found!"));
lsm6ds33.setAccelRange(LSM6DS_ACCEL_RANGE_2_G);
lsm6ds33.setGyroRange(LSM6DS_GYRO_RANGE_125_DPS);
lsm6ds33.setAccelDataRate(LSM6DS_RATE_12_5_HZ);
lsm6ds33.setGyroDataRate(LSM6DS_RATE_12_5_HZ);
lsm6ds33.configInt1(false, false, false);
/*int i=0;
char input = membrane.getKey();
char usrid[4]={0};
while(!input){}
if (input){
  usrid[i]=input;
  i++;
while(!input){}
if (input){
  usrid[i]=input;
  i++;
while(!input){}
if (input){
  usrid[i]=input;
  i++;
while(!input){}
if (input){
  usrid[i]=input;
  i++;
s= String(usrid);
//********************************Main Loop*********************************//
void loop(){
while(ss.available()>0){
gps.encode(ss.read());
if(gps.location.isUpdated()){
sensors_event_t accel;
sensors_event_t gyro;
sensors_event_t temp;
lsm6ds33.getEvent(&accel, &gyro, &temp);
currtime=millis();
Serial.print(s);
Serial.print(",");
Canbus.ecu_req(MAF_SENSOR,mafbuffer);
	  MAF2=MAF;
	  MAF = atof(mafbuffer);
    DeltaMAF=MAF-MAF2;
	 // Serial.print("Engine RPM: "); //Uncomment for Serial debugging
      Serial.print(mafbuffer);
      Serial.print(F(","));
      Serial.print(DeltaMAF);
      delay(10);
Canbus.ecu_req(VEHICLE_SPEED,vspdbuffer);
    VSPD = atoi(vspdbuffer);
    //Serial.print("Engine RPM: "); //Uncomment for Serial debugging
      Serial.print(vspdbuffer);
      delay(10);
Canbus.ecu_req(IAT,iatbuffer);
    IATMP = atoi(iatbuffer);
      Serial.print(iatbuffer);
      delay(10);
Canbus.ecu_req(ENGINE_RPM,rpmbuffer);
    RPM = atoi(rpmbuffer);
      Serial.print(rpmbuffer);
      delay(10);
     if (RPM>800){
      Serial.print(F("idling"));
      }else{
        Serial.print(F("running"));
Serial.print(accel.acceleration.x);
Serial.print(accel.acceleration.y);
Serial.print(accel.acceleration.z);
Serial.print(gyro.gyro.x);
Serial.print(gyro.gyro.y);
Serial.print(gyro.gyro.z);
Serial.print(temp.temperature);
Serial.print(gps.location.lat(), 6);
Serial.print(gps.location.lng(), 6);
deltatime=millis()-currtime;
Serial.println(deltatime);
SparkF_ThessisX.ino (4.6 KB)
Can you post an annotated schematic as to how you have wired it and include links to technical information on each of the hardware devices?
The SparkFun CanBus shield doesnt need explanation, as for the LSM6DS33 it is wired on the arduino's 13,12,11 spi lines and 9 as cs. The gps is a NEO 6m gps wired in 2,3 with softwareserial.
Good Luck!
It is not right. You need to know which pins the shield uses so as not to connect other devices to the same pins. For example, in your case...
You can't use pin 9 as CS for LSM module since it used by SD Card module on CanBus shield:
The MCP2515 IC and the microSD slot both communicate with the Arduino via the SPI lines. The CAN Chip Select line is located on D10. The SD Chip Select line is connected to D9.
I dont use the sd, secondly i have checked on other pins as cs with no success
While it still connected to the SPI bus, it doesn't matter either you using it or not
Moreover, you also use the same pin 9 for the keyboard:
You definitely need to draw up a detailed diagram of all connections, including all shield's pins, other devices, power and GND lines
