Sparkfun CCS811 sensor code not compilling
Hello.
I'm trying to use a Spakrfun breakout board CCS811 with an Arduino Nano 33 BLE Sense but the code I'm trying from Spakrfun site is not even compilling!
The guide I'm using is this:
https://learn.sparkfun.com/tutorials/ccs811-air-quality-breakout-hookup-guide/all
The code I'm using is the one that returns the errors descriptions while starting the I2C bus, but without the interrupts and Wake Up features.
This is the exact code I'm trying to compile:
  WakeAndInterrupt.ino
  Marshall Taylor @ SparkFun Electronics
  April 4, 2017
  https://github.com/sparkfun/CCS811_Air_Quality_Breakout
  https://github.com/sparkfun/SparkFun_CCS811_Arduino_Library
  This example configures the nWAKE and nINT pins.
  The interrupt pin is configured to pull low when the data is
  ready to be collected.
  The wake pin is configured to enable the sensor during I2C communications
  Hardware Connections (Breakoutboard to Arduino):
  3.3V to 3.3V pin
  GND to GND pin
  SDA to A4
  SCL to A5
  NOT_INT to D6
  NOT_WAKE to D5 (For 5V arduinos, use resistor divider)
    D5---
         R1 = 4.7K
         --------NOT_WAKE
         R2 = 4.7K
        GND
  Resources:
  Uses Wire.h for i2c operation
  Development environment specifics:
  Arduino IDE 1.8.1
  This code is released under the [MIT License](http://opensource.org/licenses/MIT).
  Please review the LICENSE.md file included with this example. If you have any questions
  or concerns with licensing, please contact techsupport@sparkfun.com.
  Distributed as-is; no warranty is given.
#include <SparkFunCCS811.h>
#define CCS811_ADDR 0x5B //Default I2C Address
//#define CCS811_ADDR 0x5A //Alternate I2C Address
// #define PIN_NOT_WAKE 5
// #define PIN_NOT_INT 6
CCS811 myCCS811(CCS811_ADDR);
//Global sensor object
void setup(){
  //Start the serial
  Serial.println("...");
  CCS811Core::status returnCode;
  //This begins the CCS811 sensor and prints error status of .begin()
  returnCode = myCCS811.begin();
  Serial.print("CCS811 begin exited with: ");
  printDriverError( returnCode );
  //This sets the mode to 60 second reads, and prints returned error status.
  returnCode = myCCS811.setDriveMode(2);
  Serial.print("Mode request exited with: ");
  //Configure and enable the interrupt line,
  //then print error status
  // pinMode(PIN_NOT_INT, INPUT_PULLUP);
  // returnCode = myCCS811.enableInterrupts();
  // Serial.print("Interrupt configuation exited with: ");
  // printDriverError( returnCode );
  // Serial.println();
  //Configure the wake line
  // pinMode(PIN_NOT_WAKE, OUTPUT);
  // digitalWrite(PIN_NOT_WAKE, 1); //Start asleep
void loop(){
  //Look for interrupt request from CCS811
  // if (digitalRead(PIN_NOT_INT) == 0)  {
    //Wake up the CCS811 logic engine
    // digitalWrite(PIN_NOT_WAKE, 0);
    //Need to wait at least 50 us
    // delay(1);
    //Interrupt signal caught, so cause the CCS811 to run its algorithm
    myCCS811.readAlgorithmResults(); //Calling this function updates the global tVOC and CO2 variables
    Serial.print("CO2[");
    Serial.print(myCCS811.getCO2());
    Serial.print("] tVOC[");
    Serial.print(myCCS811.getTVOC());
    Serial.print("] millis[");
    Serial.print(millis());
    Serial.print("]");
    //Now put the CCS811's logic engine to sleep
    //Need to be asleep for at least 20 us
    // delay(1);
  delay(1); //cycle kinda fast
//printDriverError decodes the CCS811Core::status type and prints the
//type of error to the serial terminal.
//Save the return value of any function of type CCS811Core::status, then pass
//to this function to see what the output was.
void printDriverError( CCS811Core::status errorCode ){
  switch ( errorCode )  {
    case CCS811Core::SENSOR_SUCCESS:
      Serial.print("SUCCESS");
    case CCS811Core::SENSOR_ID_ERROR:
      Serial.print("ID_ERROR");
    case CCS811Core::SENSOR_I2C_ERROR:
      Serial.print("I2C_ERROR");
    case CCS811Core::SENSOR_INTERNAL_ERROR:
      Serial.print("INTERNAL_ERROR");
    case CCS811Core::SENSOR_GENERIC_ERROR:
      Serial.print("GENERIC_ERROR");
    default:
      Serial.print("Unspecified error.");
//printSensorError gets, clears, then prints the errors
//saved within the error register.
void printSensorError(){
  uint8_t error = myCCS811.getErrorRegister();
  if ( error == 0xFF ){//comm error
    Serial.println("Failed to get ERROR_ID register.");
  }else{
    Serial.print("Error: ");
    if (error & 1 << 5) Serial.print("HeaterSupply");
    if (error & 1 << 4) Serial.print("HeaterFault");
    if (error & 1 << 3) Serial.print("MaxResistance");
    if (error & 1 << 2) Serial.print("MeasModeInvalid");
    if (error & 1 << 1) Serial.print("ReadRegInvalid");
    if (error & 1 << 0) Serial.print("MsgInvalid");
But I'm getting this errors in Arduino IDE:
Temp_Hum_Gas_rasp:125:36: error: variable or field 'printDriverError' declared void
Temp_Hum_Gas_rasp:125:36: error: 'status' is not a member of 'CCS811Core'
C:\Users\cecol\Documents\Arduino\Temp_Hum_Gas_rasp\Temp_Hum_Gas_rasp.ino: In function 'void setup()':
Temp_Hum_Gas_rasp:64:15: error: 'status' is not a member of 'CCS811Core'
Temp_Hum_Gas_rasp:67:3: error: 'returnCode' was not declared in this scope
Temp_Hum_Gas_rasp:69:3: error: 'printDriverError' was not declared in this scope
C:\Users\cecol\Documents\Arduino\Temp_Hum_Gas_rasp\Temp_Hum_Gas_rasp.ino:69:3: note: suggested alternative: 'printSensorError'
   printSensorError
C:\Users\cecol\Documents\Arduino\Temp_Hum_Gas_rasp\Temp_Hum_Gas_rasp.ino: At global scope:
A utilizar a biblioteca SparkFun_CCS811_Arduino_Library com a versão 2.0.2 na pasta: C:\Users\cecol\Documents\Arduino\libraries\SparkFun_CCS811_Arduino_Library
A usar a biblioteca Wire na directoria: C:\Users\cecol\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\3.2.0\libraries\Wire (legacy)
exit status 1
I don't know much about C++ to be able to fix the problem.
Can anyone help me?
Thanks
Psy
There is no such type defined in the library code? You probably meant CCS811Core::CCS811_Status_e, which is defined. You probably got some project code from an ancient version of the library which doesn't know to handle the current version.
