Sparkfun micro SD card shield - sample program won't compile
I just bought the micro sd shield from Sparkfun and tried running the following program from their site:
Basic example reading and writing to the microSD shield
Based on the SdFat Library by Bill Greiman
SparkFun Electronics
This example creates a file (or opens it if the file already exists) named 'Test.txt.'
A string with the value 'Millis: (number of millis)' is appended to the end of the file.
After writing to the file, the contents of the entire file are printed to the serial port.
//Add the SdFat Libraries
#include <SdFat.h>
#include <SdFatUtil.h>
#include <ctype.h>
//Create the variables to be used by SdFat Library
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
char name[] = "Test.txt"; //Create an array that contains the name of our file.
char contents[256]; //This will be a data buffer for writing contents to the file.
char in_char=0;
int index=0; //Index will keep track of our position within the contents buffer.
void setup(void)
Serial.begin(9600); //Start a serial connection.
pinMode(10, OUTPUT); //Pin 10 must be set as an output for the SD communication to work.
card.init(); //Initialize the SD card and configure the I/O pins.
volume.init(card); //Initialize a volume on the SD card.
root.openRoot(volume); //Open the root directory in the volume.
void loop(void){
file.open(root, name, O_CREAT | O_APPEND | O_WRITE); //Open or create the file 'name' in 'root' for writing to the end of the file.
sprintf(contents, "Millis: %d ", millis()); //Copy the letters 'Millis: ' followed by the integer value of the millis() function into the 'contents' array.
file.print(contents); //Write the 'contents' array to the end of the file.
file.close(); //Close the file.
file.open(root, name, O_READ); //Open the file in read mode.
in_char=file.read(); //Get the first byte in the file.
//Keep reading characters from the file until we get an error or reach the end of the file. (This will output the entire contents of the file).
while(in_char >=0){ //If the value of the character is less than 0 we've reached the end of the file.
Serial.print(in_char); //Print the current character
in_char=file.read(); //Get the next character
delay(1000); //Wait 1 second before repeating the process.
When I try compiling it, it gives the following error:
'Sd2Card' does not name a type
What does this mean and how can I fix it?
That exact program compiled OK for me, which suggests you did not install the library they would have mentioned. Or if you did install it you need to close the Arduino IDE and re-open it.
got it to work, thanks!
