that board is just connected to the socket to make it easy for you to wire, theres no electronics on it, so follow the instructions as if you were wiring directly to the card
Thanks; if the breakout board matched the pinout with 1 through to 7 I could connect as per sirmorris's post, but the labelling is:
CD
DO
GND (ok!)
SCK
VCC (3.3v?)
DI
CS
One option I can use is the microSD to SD adapter and then solder connections to the adapter, but my soldering skills aren't that great [smiley=shocked.gif]
