hi
i have this product
i pluged
pin12 to the input+
grd to input-
battery 3,7v to the battery input
and output to a led
i m using this code
int LedPin = 0;
pinMode(12, OUTPUT);
digitalWrite(LedPin ,HIGH);
digitalWrite(12, LOW);
delay(2000);
digitalWrite(12, HIGH);
delay(2000);
the led is blinking but it is always on.
it becomes brighter when it takes digitalWrite HIGH
how can i turn it off?
Thank you
Do you have a current limiting resistor on the LED?
its a 3w led and i have 1k resistor in series from sparkfun output+ to led+
also 5k resistor between pin12 and sparfun input+
its working
i did a stupid polarity reverse somewhere between
thank
kostasgian:
Okay, glad to hear you have a resistor. Is the high value intentional? You know that you are running the LED on a tiny fraction of 3W? Also, you don't need the 5k resistor.
i change te resistor to 1k
can you explain me please what do you mean that im running the LED on a tiny fraction of 3W?
im using this LED http://grobotronics.com/high-power-led-3w-cold-white-emitter.html
