First Post on the Arduino Forum , so no Flames please
I have a Sparkfun MP3 Player Shield and have downloaded the required Library.
On the WebPage for this Shield, it is stated that the Pin Layout on the Shield does not match the Pin Layout of the Arduino Board and requires re-mapping.
The WebPage states that a line of Code in the SD2Pinmap.h File needs to be changed from SS_Pin = 10; to SS_Pin = 9:
Looking into the Library Folder, there appears to be no SD2Pinmap.h File to modify!
Does this mean that the SD2Pinmap.h File has been superceded and the Website needs updating or is there another explanation?
My requirements are to operate a Model Railway Layout using this configuration;
Arduino Mega 2560R2
Freetronics Relay 8 Shield
Freetronics 16X2 LCD Shield
I know that I will end up with various Pin conflicts, (which is why I purchased the Mega), so I'm getting each Shield up & running separately and then attempting to remap the Pins and combine the Code later.
Note that theMP3 chip and SD Card both use the SPI interface. On the Arduino Mega the SPI interface is on completely different pins. You will not be able to plug the board onto an Arduino Mega and expect it to work. Some cards, like the Ethernet Shield, use the ICSP header to connect to most of the SPI pins. That header is in the same position on both the Arduino UNO and Arduino Mega so the Ethernet Shield will work on both. This MP3 Shield doesn't do that so you will have to re-wire manually. See the SPI library documentation for pin numbers.
As for using Pin 9 instead of the default, just pass the pin number to SD.begin();
Thanks John, I've re-evaluated my need for the LCD and have decided to keep the Laptop in the Loop temporarily so I can use the Serial println Command to feed the required info back to the Operator. This will keep the Pin conflicts to a minimum.
Imagineering:
Arduino Mega 2560R2
Any help is appreciated.
The MP3 player shield will definitely need manual rewiring, according to the schematic it also uses D6~D9 which will interfere with your LCD Keypad Shield.
Thanks Johnft, we must have either cross-posted or my meaning in my last reply wasn't clear. To alleviate the Pin conflicts I won't be using the LCD in the Stack.
Imagineering:
Thanks Johnft, we must have either cross-posted or my meaning in my last reply wasnโt clear. To alleviate the Pin conflicts I wonโt be using the LCD in the Stack.
No worries. Good luck with the project, sounds interesting
Thank you for all your replies. What I think I need to do, is to leave this part of the Project alone until I get the Layout up and running and acquire more Coding ability and then come back to this part with a better understanding.
