SparkFun OBD-II UART not Returning Data
I am trying to get the car fuel level and coolant temperature of a car via a SParkfun OBD-II UART Board and Arduino Pro Micro. Here is my code.
#include <SoftwareSerial.h>
//This is a character buffer that will store the data from the serial port
char rxData[20];
char rxIndex=0;
//Variables to hold the speed and RPM data.
int vFuel=0;
int vTemp=0;
void setup(){
  //Use Serial to display data
  while(!Serial){
    ; // if not ready, wait
  //Use Serial1 to communicate with vehicle
  Serial1.begin(9600);
  while(!Serial1){
  //Wait for a little while before sending the reset command to the OBD-II-UART
  delay(1500);
  //Reset the OBD-II-UART
  Serial1.println("ATZ");
  //Wait for a bit before starting to send commands after the reset.
  delay(2000);
  //Delete any data that may be in the serial port before we begin.
  Serial1.flush();
void loop(){
  Serial1.flush();
  //Query the OBD-II-UART for the Vehicle Fuel Level
  Serial1.println("012F");
  //Get the response from the OBD-II-UART board. We get two responses
  //because the OBD-II-UART echoes the command that is sent.
  //We want the data in the second response.
  delay(200);
  getResponse();
  getResponse();
  //Convert the string data to an integer
  vFuel = strtol(&rxData[6],0,16);
  vFuel = 1.0 * vFuel / 255 * 100; // in the scale of 100
  //Print the speed data to the lcd
  Serial.print("Fuel: " + vFuel);
  Serial.print(" %");
  Serial.println("   ");
  delay(100);
  //Delete any data that may be left over in the serial port.
  Serial1.flush();
  //Query the OBD-II-UART for the Vehicle coolant temperature
  Serial1.println("0105");
  getResponse();
  getResponse();
  //NOTE: RPM data is two bytes long, and delivered in 1/4 RPM from the OBD-II-UART
  vTemp = strtol(&rxData[6], 0, 16);
  vTemp = vTemp - 40; // offset by 0
  //Print the rpm data to the lcd
  Serial.print("Temp: " + vTemp);
  Serial.print(" C");
  //Give the OBD bus a rest
  delay(100);
//The getResponse function collects incoming data from the UART into the rxData buffer
// and only exits when a carriage return character is seen. Once the carriage return
// string is detected, the rxData buffer is null terminated (so we can treat it as a string)
// and the rxData index is reset to 0 so that the next string can be copied.
void getResponse(void){
  char inChar=0;
  //Keep reading characters until we get a carriage return
  while(inChar != '\r'){
    //If a character comes in on the serial port, we need to act on it.
    if(Serial1.available() > 0){
      //Start by checking if we've received the end of message character ('\r').
      if(Serial1.peek() == '\r'){
        //Clear the Serial buffer
        inChar=Serial1.read();
        //Put the end of string character on our data string
        rxData[rxIndex]='\0';
        //Reset the buffer index so that the next character goes back at the beginning of the string.
        rxIndex=0;
      //If we didn't get the end of message character, just add the new character to the string.
      else{
        //Get the new character from the Serial port.
        inChar = Serial1.read();
        //Add the new character to the string, and increment the index variable.
        rxData[rxIndex++]=inChar;
Here is the output I get from the serial monitor:
Fuel: %
TZ C
Fuel: %
TZ C
Fuel: %
TZ C
Fuel: %
TZ C
Is my code ok? Please help.
did you check the hookup guide?
https://learn.sparkfun.com/tutorials/obd-ii-uart-hookup-guide/all
in any case since you are using a pro micro, you don't really need to code anything on it. just connect the TX from the board to the TX of the pro micro and same for RX (if that does not work try to swap the connection around)
then all you need to do next is open the IDE serial monitor and type in your commands (same as in the hookup guide. don't forget to set the baudrate and line ending correctly!).
let us know if it works when you sent it up that way. good luck!
The Arduino Pro Micro does not have a Serial1 port. Use the softwareserial.h library to use since it's already included in your sketch. Only then will you be able to get any data at all.
Power_Broker:
Actually he is using softwareserial.h! just noticed in his code that OP did not(forgot?) to instate Serial1(RX_pin, TX_pin) (as you would when using softwareserial lib)
