SparkFun RGB LED Backpack Blinking Lights
Sorry, no video here. Which is too bad because it looks pretty cool.
// Blinking LEDs
// Simple program to test SPI with the RGB Matrix and Backpack from Sparkfun.
// Revised 2009.12.24
// Credits:
//   Heather Dewey-Hagborg
//   Arduino Forum user Little-Scale
//   Daniel Hirschmann
//   Arduino Forum user chessplayer
// SPI register bit positions
#define RX_IN  0
#define TX_OUT 1
#define CS     2
#define MOSI   3
#define MISO   4
#define SCK    5
// Ardrino Duemilanove pin numbers for SPI
#define CHIPSELECT 10 // CS
#define DATAOUT    11 // MOSI
#define DATAIN     12 // MISO (not used)
#define SPICLOCK   13 // SCK
// SparkFun RGB LED backpack officially supported colors
typedef unsigned char ledcolorType;
#define colorBlack   0x00
#define colorRed     0xe0
#define colorGreen   0x1c
#define colorBlue    0x03
#define colorOrange  0xfc
#define colorMagneta 0xe3
#define colorTeal    0x1f
#define colorWhite   0xff
#define colorLen 8
static const ledcolorType colors[colorLen] =
  colorBlack,  colorRed,     colorGreen, colorBlue,
  colorOrange, colorMagneta, colorTeal,  colorWhite
// SparkFun RGB LED backpack frame geometry
#define rowLen 8
#define colLen 8
typedef struct
  ledcolorType pixels[rowLen][colLen];
} frameType;
static void SetFrameToColor(frameType& frame, const ledcolorType color)
  for (unsigned int col = 0; col < colLen; col++)
    for (unsigned int row = 0; row < rowLen; row++)
      frame.pixels[row][col] = color;
static void SetFrameToBlack(frameType& frame) {SetFrameToColor(frame, colorBlack);}
static unsigned char PickRandomColor(void) {return colors[random(colorLen)];}
static void ChangeOneRandomPixelToColor(frameType& frame, const ledcolorType color)
  frame.pixels[random(rowLen)][random(colLen)] = color;
static void SetBackpackSelectStatus(const unsigned int status)
  digitalWrite(CHIPSELECT, status); delayMicroseconds(500);
static void BackpackEnable(void)  {SetBackpackSelectStatus(LOW);}
static void BackpackDisable(void) {SetBackpackSelectStatus(HIGH);}
static unsigned char WriteSPIByte(unsigned char data)
  SPDR = data; while (!(SPSR & (1 << SPIF))); return SPDR;
static void SetBackpackDaisyChainLength(const unsigned int length)
  BackpackEnable();
  WriteSPIByte('%'); WriteSPIByte(length);
  BackpackDisable();
static void WriteFrame(const frameType& frame)
  BackpackEnable();
      WriteSPIByte(frame.pixels[row][col]);
  BackpackDisable();
// The last real frame displayed
static frameType realframe;
// One time setup
  // Initialize the Arduino SPI pin directions
  pinMode(CHIPSELECT, OUTPUT);
  pinMode(DATAIN,     INPUT);
  pinMode(DATAOUT,    OUTPUT);
  pinMode(SPICLOCK,   OUTPUT);
  // Magical initialization of the SPI registers
  volatile byte clr;
  DDRB = (1 << CS) | (1 << MOSI) | (1 << SCK);
  DDRD = (1 << TX_OUT);
  SPCR = (1 << SPE) | (1 << MSTR) | (1 << SPR1);
  SPSR = SPSR & 0xfe;
  clr = SPSR; clr = SPDR;
  // Set the backpack to its default state
  BackpackDisable();
  SetBackpackDaisyChainLength(1);  // Be careful with this one
  // Initial display is all black pixels
  SetFrameToBlack(realframe); WriteFrame(realframe);
// Main loop
  delay(100);
  ChangeOneRandomPixelToColor(realframe, PickRandomColor());
How about some pictures? :sunglasses:
I'll try to put up a video after I get a youtube account.
