I don't seem to be able to make the strip work with my own code.
The example code works but everytime I try to modify it I can't seem to get it to work ok. I just get the first LED changing colour randomly.
The example code is at http://www.sparkfun.com/datasheets/Components/LED/LED_Strip_Example.pde
Any pointers would be most appreciated!
Here's some code that I've written.
Blue = 5V
Red = SDI
Green = CKI
Black = GND
int SDI = 2; //Red wire (not the red 5V wire!)
int CKI = 3; //Green wire
int ledPin = 13; //On board LED
long p[4096];
pinMode(SDI, OUTPUT);
pinMode(CKI, OUTPUT);
pinMode(ledPin, OUTPUT);
//clear data in the RGB strip
for (int x = 0; x < 32; x++) {
pushRGB(0x000000);
digitalWrite(CKI, LOW);
delayMicroseconds(500);
loaddata();
pushRGB(p[x]);
void pushRGB (long colour) {
for(byte color_bit = 23 ; color_bit != 255 ; color_bit--) {
//Feed color bit 23 first (red data MSB)
digitalWrite(CKI, LOW); //Only change data when clock is low
long mask = 1L << color_bit;
//The 1'L' forces the 1 to start as a 32 bit number, otherwise it defaults to 16-bit.
if(colour & mask)
digitalWrite(SDI, HIGH);
digitalWrite(SDI, LOW);
digitalWrite(CKI, HIGH); //Data is latched when clock goes high
void loaddata() {
p[0] = 0xFF3B36;
p[1] = 0xFF1F18;
p[2] = 0xFF1408;
p[3] = 0xFF1703;
p[4] = 0xFF2602;
p[5] = 0xFF3D03;
p[6] = 0xFF5F05;
p[7] = 0xFE8B0A;
p[8] = 0xFEB90D;
p[9] = 0xFEDE0E;
p[10] = 0xFEF40B;
p[11] = 0xFEFC07;
p[12] = 0xFDFE05;
p[13] = 0xF9FF07;
p[14] = 0xF2FF0E;
p[15] = 0xE4FF1E;
p[16] = 0xCBFF39;
p[17] = 0xA5FE60;
p[18] = 0x78FD8F;
p[19] = 0x52F9B9;
p[20] = 0x3DF2DA;
p[21] = 0x3EE6ED;
p[22] = 0x57D2F8;
p[23] = 0x83B6FD;
p[24] = 0xB493FE;
p[25] = 0xDB6BFF;
p[26] = 0xF144FF;
p[27] = 0xFB25FE;
p[28] = 0xFD10FE;
p[29] = 0xFD07FE;
p[30] = 0xFD08FD;
p[31] = 0xFC13FC;
p[32] = 0xFF3933;
p[33] = 0xFF2016;
p[34] = 0xFF1808;
p[35] = 0xFF1D02;
p[36] = 0xFF2E02;
p[37] = 0xFF4703;
p[38] = 0xFF6905;
p[39] = 0xFE9309;
p[40] = 0xFEBE0D;
p[41] = 0xFEE10D;
p[42] = 0xFEF50A;
p[43] = 0xFDFC07;
p[44] = 0xFBFE06;
p[45] = 0xF6FF0A;
p[46] = 0xEDFF14;
p[47] = 0xDDFF25;
p[48] = 0xC3FE41;
p[49] = 0x9EFD68;
p[50] = 0x74FB95;
p[51] = 0x52F7BE;
p[52] = 0x42EEDC;
p[53] = 0x47DFEF;
p[54] = 0x60CAF9;
p[55] = 0x8BADFD;
p[56] = 0xB98AFE;
p[57] = 0xDD64FF;
p[58] = 0xF240FE;
p[59] = 0xFB23FE;
p[60] = 0xFC11FD;
p[61] = 0xFC09FC;
p[62] = 0xFA0CFA;
p[63] = 0xF918F9;
p[64] = 0xFF372F;
p[65] = 0xFF2115;
p[66] = 0xFF1C07;
p[67] = 0xFF2502;
p[68] = 0xFF3802;
p[69] = 0xFF5203;
p[70] = 0xFE7305;
p[71] = 0xFE9B09;
p[72] = 0xFEC40C;
p[73] = 0xFEE40C;
p[74] = 0xFDF60A;
p[75] = 0xFCFD07;
p[76] = 0xF9FE08;
p[77] = 0xF2FF0E;
p[78] = 0xE6FF1A;
p[79] = 0xD4FF2D;
p[80] = 0xBAFE4A;
p[81] = 0x97FD71;
p[82] = 0x71F99B;
p[83] = 0x54F3C2;
