Arduija: Arduino Controlled Ouija Board
Joel Bartlett
Casey Kuhns
SparkFun Electronics
Oct. 22, 2014
https://github.com/JoelEB/Arduija2_1_1
This sketch uses the AccelStepper Library to controll two stpper motors,
driven by two Big Easy Driver boards from SparkFun. Letters on a Ouija
board are mapped out, given coordinates, and then massages are spelled
out by looking up the coordinates in that table.
Development environment specifics:
Arduino IDE .0+
Arduino Uno
This code is beerware; if you see me at the local pub,
and you've found our code helpful, please buy us a round!
Distributed as-is; no warranty is given.
#include <avr/pgmspace.h>
#include <AccelStepper.h>//include the Accel Stepper Library
#define MAX_ARRAY_LENGTH 32
// Define two steppers and the pins they will use
AccelStepper stepperX(1, 4, 5);//X axis
AccelStepper stepperY(1, 6, 7);//Y axis
//(driver=true, step, dir)
int enableX = 10;//pins to controll the enable pins on each of the Big Easy Drivers
int enableY = 11;//I tried using the intenral setEnablePin() function in the AccelStepper library
//but couldn't get it to work, even when I inverted them with setPinsInverted().
int posX = 0;//Varibales to keep track of the planchet's current position
int posY = 0;
int switch_x_left = 8;//Limit switch variables
int switct_y_top = 9;
int switch_x_right = 3;//trying to set these up as interrupts (W.I.P.)
int switch_y_bottom = 2;
int bigButton = 12;//Added big dome pushbutotn to have it display a message when pressed.
//Original plan was to have it run constantly, but the smaller stepper motor (ROB-09238)
//gets hot when ran for even a shoirt while. I'm pushing it past it's max ratings. I would
//recommend using a 68oz.-in. motor (ROB-10846) on both axes. Make sure you disable all motors
//when not in use to minimize heat dissipation and power consumption.
long randomNumber;//Random number for displaying random message when butotn is pressed.
//table to store coordinates for all the letters, #s, etc on the board.
//Due to the nature of the magnets and drag, getting exact coordinates took
//lots of trial an error, and is still not perfect when you have the planchet
//move in from different sides of the letter.
unsigned int coordinatesTable[39][3] = {
1000,2600,'a',
2800,1900,'b',
4400,1700,'c',
6100,1500,'d',
8200,1300,'e',
9300,1100,'f',
11800,1200,'g',
13700,1200,'h',
15500,1100,'i',
16800,1500,'j',
18700,1700,'k',
20300,2100,'l',
22800,2500,'m',
1200,4500,'n',
2500,3900,'o',
4300,3400,'p',
6000,3200,'q',
7900,2800,'r',
9700,2600,'s',
11500,2600,'t',
13600,2700,'u',
15400,2700,'v',
17200,2800,'w',
19400,3400,'x',
20800,4000,'y',
22800,4500,'z',
0,0,'0',
0,0,'1',
0,0,'2',
0,0,'3',
0,0,'4',
0,0,'5',
0,0,'6',
0,0,'8',
0,0,'9',
4400,10,'+',//YES
19900,10,'-',//NO
0,0,'!',//GOODBYE
11700,100,'.'//SPACE
Serial.begin(115200);//Serial print for debug
pinMode(bigButton, INPUT_PULLUP);//Pullup button so external resistor is not needed
randomSeed(analogRead(0));//Read analog(0) for random number generation
pinMode(enableX, OUTPUT);//
pinMode(enableY, OUTPUT);
digitalWrite(enableX, HIGH);//Diable the motors
digitalWrite(enableY, HIGH);
//Had to play with these vallues to find a speed and acceleration that looked good
//but also still ran smoothly. Tweeking these values and physically changing the
//potentiometers on the Big Easy Driver will affect the speed of each axis.
//BEWARE, changing these settings will change coordinates and mess up any characters
//you have mapped out already.
stepperX.setMaxSpeed(6000);
stepperX.setAcceleration(5000);
stepperY.setMaxSpeed(4000);
stepperY.setAcceleration(4000);
//This is the internal AccelStepper enable calls referred to
//earlier. Must be called within setup() (W.I.P.)
//stepperX.setEnablePin(10);
//stepperY.setEnablePin(11);
//stepperX.setPinsInverted(0,0,1);//invert the enable pin
//stepperY.setPinsInverted(0,0,1);
pinMode(switch_x_left, INPUT_PULLUP);
pinMode(switct_y_top, INPUT_PULLUP);
pinMode(switch_x_right, INPUT_PULLUP);
pinMode(switch_y_bottom, INPUT_PULLUP);
//Switch interrupts to ensure the planchet never goes out of bounds (W.I.P.)
//attachInterrupt(0, homeing2, FALLING); //switct_y_bottom
//attachInterrupt(1, homeing2, FALLING);//switch_x_right
homeing();//set the cursor back to its home position at 0,0 first and on every reset
if(digitalRead(bigButton) == LOW)//Wait until the big dome pusbutton is pressed to start spelling a message
ouijaMessage();//Select a random message from the list and print it
//Uncomment this line and comment out everything else in loop() to jog the planchet with keyboard inputs
//moveWithKeyboard();
void enableMotors()
//Enable the motors
digitalWrite(enableX, LOW);
digitalWrite(enableY, LOW);
void disableMotors()
//Disable the motors
void homeing()
enableMotors();
//Decided to move Y axis first since one of the magnets was hitting if it was all the way away from home.
if(digitalRead(switct_y_top) == HIGH)
while(digitalRead(switct_y_top) == HIGH)
stepperY.moveTo(posY);
stepperY.run();
posY = posY - 1;
//Serial.println(posY);
if(digitalRead(switct_y_top) == LOW)
stepperY.stop();
posY = 0;
stepperY.setCurrentPosition(0);
posY = 0;
if(digitalRead(switch_x_left) == HIGH)//check to make sure this axis isn;t already in the home posotion
while(digitalRead(switch_x_left) == HIGH)//if it is not at home (HIGH) ...
stepperX.moveTo(posX);//start moving the X axis back to the home position
stepperX.run();
posX = posX - 1;//decrement the position until we reach 0 (where the switch is triggered)
if(digitalRead(switch_x_left) == LOW)//Once the switch is hit and the signal goes LOW...
stepperX.stop();//stop the motor
posX = 0;//set this axis position to 0
stepperX.setCurrentPosition(0);
posX = 0;
disableMotors();
