Sparkfun TCA9548A Qwiic Mux
I want to read with an Uno from 5 different Sparkfun Grid-Eye sensors connected to the TCA9548A mux. Does anyone have any code for this? The Grid Eye sensors all have the same i2c address.
they have a library for the MUX with examples
Dear J-M-L
Many thanks for getting back to me. I have downloaded the Example1_BasicControl from the library you referenced but my problem is that I can’t figure out how to add the code to read from the Grid-Eye sensors.
Would you be able to advise?
Kind regards
Robert Mayo
you use the library to set the active MUX port (where I2C commands will go) by using mux.setPort(xxx); where mux is your QWIICMUX instance and xxx the port you want to select.
Once this is done you send a normal command to your Sparkfun Grid-Eye sensor, it will be routed to the sensor attached to the active MUX port
Dear J-M-L
I am a novice and greatly appreciate your help with this.
Assume “mux.setPort” goes under void setup(). Do I need to include Wire.begin().
Have copied my code, which works 100% when I connect the Grid-Eye directly to the Arduino over i2c, but the code does not work when I copy it into the void loop() of the mux code.
Any suggestions you might have would be very helpful.
Regards
Robert Mayo
Hello Robert
nothing wrong being a novice, we all started there.
I would suggest to study the examples that come with the library , start with Example1_BasicControl.ino
you'll see how they set it up.
Dear J-M-L
Many thanks for your first class help. Have now got the application working. A great feeling!
Best regards
Robert
great news. Have fun
