SPDT switch in software
I (might) need to make a sort of software-controlled SPDT switch to connect one of two different inputs to a single outputs. I'm talking about analog signals.
No problems for the software part, but what about the hardware? I guess I could use a relay, but was wondering if there is any non-mechanical solution.
Or maybe would even a dual-input multiplexer IC work?
You mean a 74HC4053?
Well, that is exactly what it is for.
Mmmh... I have a few HC157 handy, will they be fine as well?
http://www.nxp.com/documents/data_sheet/74HC_HCT157.pdf
I know how multiplexers work, but have always used them with digital signals, never put anything analog into them.
Of course, you can't use a digital part for analogue signals.
Or you could use a MAX4644 which seems to be a much simpler chip design.
SukkoPera:
Well, since the term "analog" occurs nowhere in the documentation, that should be a strong hint.
jackrae:
Sure is, but how readily available?
Paul__B:
:smiley:
OK, so there are dedicated multiplexers for analog signals, I didn't know this!
Paul__B:
Mouser Electronics in UK list 2441 in stock !
As far as I understand, the MAX4644 is not available in DIP thought, which complicates things.
The 4053 doesn't seem so complex to use, anyway, I'll go with that.
