Speaker issues due to coding
Hi im trying to get my arduino to play a song through a speaker and where i can stop it and make it play when ever i want.
I found a code and used it, yet when i transfer it to my main code it doesn't work.
I am using an arduino mega and i wil post my schematich.
Speak UP Click HELPPPPP!!!!!!.pdf (1.1 MB)
Song code:
  tone() Melody Player With Melodies Converted From rock-a-bye-baby-tune-a.mid
  1. Save or copy-and-paste this file into the Arduino IDE
  2. Configure the tonePin variable
  3. Edit the melodyToPlay and tempoToPlay in the loop
  Wiring: Attach a typical piezo element between the tonePin defined below
  and ground.  Maybe put a resistor in series too if you are feeling cautious.
static const uint8_t tonePin = 12;
  // Here is where you choose the melody and the tempo (speed) to play it at
  // The melody is numbered from 0 .. 0
  // The tempo is a value from 1 .. 255, where 1 is fast and 255 is extremely
  // slow.  The tempo a given melody sounds best at varies a lot, you just have
  // to experiment, some sound good at tempo 1, some might need tempo 50!
  uint8_t melodyToPlay = 0;
  uint8_t tempoToPlay  = 4;
  playMelody(melodyToPlay, tempoToPlay);
  // Unless you have changed them, these were the melodies which we extracted
  // from rock-a-bye-baby-tune-a.mid and are encoded below in
  // the Melody Data section.
  // 0 - Piano
// End of the normally edited bits of the sketch, the rest of this file is
// the data for the melodies, and the supporting functions, carry on down
// by all means, but if you just want to play the melody, you don't need to
// go any further.
#include <avr/pgmspace.h>
// Melody Data
// This is the human readable/editable version of melodies.  We start by making
// some macros for each of the 12 notes we can play in each of the 8 octaves
// we can (maybe, depending on your tone()'s abilities) play.
// If you scroll down to after these macros you will see how they are used to
// construct arrays of notes/silences that make up each melody.
// The "DURATION" is the duration of the note to play (or silence) in units
// of tempo.  For example, to encode a C in the 4th Octave (commonly
// called Middle-C) for 10ms with a "tempoToPlay = 5" (ms), that would be
//  NOTE_C_4(2)
// because 2 durations of a 5ms tempo is 10ms :-)
// The maximum duration for a note or silence is 255, if you need longer, then
// simply use two notes and they will join togethor, eg for a 355 duration...
//  NOTE_C_4(255), NOTE_C_4(100)
// Octave 0 Note Codes
#define       NOTE_C_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000000)
#define      NOTE_CS_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000001)
#define       NOTE_D_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000010)
#define      NOTE_DS_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000011)
#define       NOTE_E_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000100)
#define       NOTE_F_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000101)
#define      NOTE_FS_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000110)
#define       NOTE_G_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00000111)
#define      NOTE_GS_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00001000)
#define       NOTE_A_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00001001)
#define      NOTE_AS_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00001010)
#define       NOTE_B_0(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00001011)
// Octave 1 Note Codes
#define       NOTE_C_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010000)
#define      NOTE_CS_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010001)
#define       NOTE_D_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010010)
#define      NOTE_DS_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010011)
#define       NOTE_E_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010100)
#define       NOTE_F_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010101)
#define      NOTE_FS_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010110)
#define       NOTE_G_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00010111)
#define      NOTE_GS_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00011000)
#define       NOTE_A_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00011001)
#define      NOTE_AS_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00011010)
#define       NOTE_B_1(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00011011)
// Octave 2 Note Codes
#define       NOTE_C_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100000)
#define      NOTE_CS_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100001)
#define       NOTE_D_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100010)
#define      NOTE_DS_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100011)
#define       NOTE_E_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100100)
#define       NOTE_F_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100101)
#define      NOTE_FS_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100110)
#define       NOTE_G_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00100111)
#define      NOTE_GS_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00101000)
#define       NOTE_A_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00101001)
#define      NOTE_AS_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00101010)
#define       NOTE_B_2(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00101011)
// Octave 3 Note Codes
#define       NOTE_C_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110000)
#define      NOTE_CS_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110001)
#define       NOTE_D_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110010)
#define      NOTE_DS_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110011)
#define       NOTE_E_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110100)
#define       NOTE_F_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110101)
#define      NOTE_FS_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110110)
#define       NOTE_G_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00110111)
#define      NOTE_GS_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00111000)
#define       NOTE_A_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00111001)
#define      NOTE_AS_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00111010)
#define       NOTE_B_3(DURATION) ( (((uint16_t)DURATION)<<8) | 0b00111011)
// Octave 4 Note Codes
#define       NOTE_C_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000000)
#define      NOTE_CS_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000001)
#define       NOTE_D_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000010)
#define      NOTE_DS_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000011)
#define       NOTE_E_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000100)
#define       NOTE_F_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000101)
#define      NOTE_FS_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000110)
#define       NOTE_G_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01000111)
#define      NOTE_GS_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01001000)
#define       NOTE_A_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01001001)
#define      NOTE_AS_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01001010)
#define       NOTE_B_4(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01001011)
// Octave 5 Note Codes
#define       NOTE_C_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010000)
#define      NOTE_CS_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010001)
#define       NOTE_D_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010010)
#define      NOTE_DS_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010011)
#define       NOTE_E_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010100)
#define       NOTE_F_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010101)
#define      NOTE_FS_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010110)
#define       NOTE_G_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01010111)
#define      NOTE_GS_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01011000)
#define       NOTE_A_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01011001)
#define      NOTE_AS_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01011010)
#define       NOTE_B_5(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01011011)
// Octave 6 Note Codes
#define       NOTE_C_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100000)
#define      NOTE_CS_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100001)
#define       NOTE_D_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100010)
#define      NOTE_DS_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100011)
#define       NOTE_E_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100100)
#define       NOTE_F_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100101)
#define      NOTE_FS_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100110)
#define       NOTE_G_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01100111)
#define      NOTE_GS_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01101000)
#define       NOTE_A_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01101001)
#define      NOTE_AS_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01101010)
#define       NOTE_B_6(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01101011)
// Octave 7 Note Codes
#define       NOTE_C_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110000)
#define      NOTE_CS_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110001)
#define       NOTE_D_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110010)
#define      NOTE_DS_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110011)
#define       NOTE_E_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110100)
#define       NOTE_F_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110101)
#define      NOTE_FS_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110110)
#define       NOTE_G_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01110111)
#define      NOTE_GS_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01111000)
#define       NOTE_A_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01111001)
#define      NOTE_AS_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01111010)
#define       NOTE_B_7(DURATION) ( (((uint16_t)DURATION)<<8) | 0b01111011)
// Octave 8 Note Codes
#define       NOTE_C_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000000)
#define      NOTE_CS_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000001)
#define       NOTE_D_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000010)
#define      NOTE_DS_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000011)
#define       NOTE_E_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000100)
#define       NOTE_F_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000101)
#define      NOTE_FS_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000110)
#define       NOTE_G_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10000111)
#define      NOTE_GS_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10001000)
#define       NOTE_A_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10001001)
#define      NOTE_AS_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10001010)
#define       NOTE_B_8(DURATION) ( (((uint16_t)DURATION)<<8) | 0b10001011)
#define    NOTE_SILENT(DURATION) ((((uint16_t)DURATION)<<8) | 0b00001111)
// The melodies must be named Melody0 .. Melody{NUMBER_OF_MELODIES-1}, and
// each must also have a MelodyX_Length defined.
#define NUMBER_OF_MELODIES 1
// Track 0 - Piano
static const uint16_t Melody0[] PROGMEM = {
            NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4(  55 ),  NOTE_SILENT(   9 ),
            NOTE_D_5(  58 ),  NOTE_SILENT(   6 ),     NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4( 116 ),  NOTE_SILENT(  12 ),
            NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_G_3( 122 ),  NOTE_SILENT(   6 ),
            NOTE_D_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_F_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_E_4( 255 ),     NOTE_E_4( 110 ),  NOTE_SILENT(  19 ),     NOTE_C_4( 122 ),
         NOTE_SILENT(   6 ),     NOTE_E_4(  55 ),  NOTE_SILENT(   9 ),     NOTE_F_5(  58 ),
         NOTE_SILENT(   6 ),     NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_C_4( 122 ),
         NOTE_SILENT(   6 ),     NOTE_E_4( 116 ),  NOTE_SILENT(  12 ),     NOTE_G_4( 122 ),
         NOTE_SILENT(   6 ),     NOTE_B_3( 122 ),  NOTE_SILENT(   6 ),     NOTE_D_4( 122 ),
         NOTE_SILENT(   6 ),     NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4( 255 ),
            NOTE_E_4( 110 ),  NOTE_SILENT(  19 ),     NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_E_4(  55 ),  NOTE_SILENT(   9 ),     NOTE_D_5(  58 ),  NOTE_SILENT(   6 ),
            NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_E_4( 116 ),  NOTE_SILENT(  12 ),     NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_B_3( 122 ),  NOTE_SILENT(   6 ),     NOTE_D_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_D_4( 116 ),  NOTE_SILENT(  12 ),     NOTE_F_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_D_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_F_4( 116 ),  NOTE_SILENT(  12 ),     NOTE_G_4( 122 ),  NOTE_SILENT(   6 ),
            NOTE_F_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4( 255 ),     NOTE_E_4( 110 ),
         NOTE_SILENT(  19 ),     NOTE_C_4( 122 ),  NOTE_SILENT(   6 ),     NOTE_E_4(  55 ),
         NOTE_SILENT(   9 ),     NOTE_D_5(  58 ),  NOTE_SILENT(   6 ),     NOTE_G_4( 122 ),
static const uint16_t Melody0_Length    = sizeof( Melody0 ) / sizeof(uint16_t);
/** Play a melody.
 * Provide the MelodyX and MelodyX_Length as well as a tempo for the melody to play it on
 * tonePin (defined above).
void playMelody_Data(const uint16_t MelodyData[], const uint16_t MelodyLength, const uint8_t tempo)
  // 8th Octave Frequencies C8 to B8, lower octaves are calculated from this
  static const uint16_t Freq8[] PROGMEM = { 4186 , 4435 , 4699  , 4978 , 5274 , 5588 , 5920 , 6272 , 6645 , 7040 , 7459 , 7902 };
  for(uint16_t  x = 0; x < MelodyLength; x++)
    uint16_t data = pgm_read_word((uint16_t *)&MelodyData[x]);
    if((data & 0xF) == 0xF)
      noTone(tonePin);
      uint16_t Freq = pgm_read_word(&Freq8[data&0xF]) / ( 1 << (8-(data>>4 & 0xF)) );
      tone(tonePin, Freq);
    int16_t Duration = data>>8;
    while(Duration--) delay(tempo);
/** Play a melody by number, with a given tempo.
 *  This looks like a big clunky function, but the optimiser will
 *  "inline" it and this will mean that provided the N you provide
 *  is a constant value, the compiler doesn't need to include the
 *  data of any of the non-used melodies, and can jump straight into
 *  the appropriate playMelody_Data call.
inline static void playMelody(uint8_t melodyNumber, uint8_t tempo)
  switch(melodyNumber)
  #if NUMBER_OF_MELODIES > 0
    case 0: { playMelody_Data(Melody0, Melody0_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 1
    case 1: { playMelody_Data(Melody1, Melody1_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 2
    case 2: { playMelody_Data(Melody2, Melody2_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 3
    case 3: { playMelody_Data(Melody3, Melody3_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 4
    case 4: { playMelody_Data(Melody4, Melody4_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 5
    case 5: { playMelody_Data(Melody5, Melody5_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 6
    case 6: { playMelody_Data(Melody6, Melody6_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 7
    case 7: { playMelody_Data(Melody7, Melody7_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 8
    case 8: { playMelody_Data(Melody8, Melody8_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 9
    case 9: { playMelody_Data(Melody9, Melody9_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 10
    case 10: { playMelody_Data(Melody10, Melody10_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 11
    case 11: { playMelody_Data(Melody11, Melody11_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 12
    case 12: { playMelody_Data(Melody12, Melody12_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 13
    case 13: { playMelody_Data(Melody13, Melody13_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 14
    case 14: { playMelody_Data(Melody14, Melody14_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 15
    case 15: { playMelody_Data(Melody15, Melody15_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 16
    case 16: { playMelody_Data(Melody16, Melody16_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 17
    case 17: { playMelody_Data(Melody17, Melody17_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 18
    case 18: { playMelody_Data(Melody18, Melody18_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 19
    case 19: { playMelody_Data(Melody19, Melody19_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 20
    case 20: { playMelody_Data(Melody20, Melody20_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 21
    case 21: { playMelody_Data(Melody21, Melody21_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 22
    case 22: { playMelody_Data(Melody22, Melody22_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 23
    case 23: { playMelody_Data(Melody23, Melody23_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 24
    case 24: { playMelody_Data(Melody24, Melody24_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 25
    case 25: { playMelody_Data(Melody25, Melody25_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 26
    case 26: { playMelody_Data(Melody26, Melody26_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 27
    case 27: { playMelody_Data(Melody27, Melody27_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 28
    case 28: { playMelody_Data(Melody28, Melody28_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 29
    case 29: { playMelody_Data(Melody29, Melody29_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 30
    case 30: { playMelody_Data(Melody30, Melody30_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 31
    case 31: { playMelody_Data(Melody31, Melody31_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 32
    case 32: { playMelody_Data(Melody32, Melody32_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 33
    case 33: { playMelody_Data(Melody33, Melody33_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 34
    case 34: { playMelody_Data(Melody34, Melody34_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 35
    case 35: { playMelody_Data(Melody35, Melody35_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 36
    case 36: { playMelody_Data(Melody36, Melody36_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 37
    case 37: { playMelody_Data(Melody37, Melody37_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 38
    case 38: { playMelody_Data(Melody38, Melody38_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 39
    case 39: { playMelody_Data(Melody39, Melody39_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 40
    case 40: { playMelody_Data(Melody40, Melody40_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 41
    case 41: { playMelody_Data(Melody41, Melody41_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 42
    case 42: { playMelody_Data(Melody42, Melody42_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 43
    case 43: { playMelody_Data(Melody43, Melody43_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 44
    case 44: { playMelody_Data(Melody44, Melody44_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 45
    case 45: { playMelody_Data(Melody45, Melody45_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 46
    case 46: { playMelody_Data(Melody46, Melody46_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 47
    case 47: { playMelody_Data(Melody47, Melody47_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 48
    case 48: { playMelody_Data(Melody48, Melody48_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 49
    case 49: { playMelody_Data(Melody49, Melody49_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 50
    case 50: { playMelody_Data(Melody50, Melody50_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 51
    case 51: { playMelody_Data(Melody51, Melody51_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 52
    case 52: { playMelody_Data(Melody52, Melody52_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 53
    case 53: { playMelody_Data(Melody53, Melody53_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 54
    case 54: { playMelody_Data(Melody54, Melody54_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 55
    case 55: { playMelody_Data(Melody55, Melody55_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 56
    case 56: { playMelody_Data(Melody56, Melody56_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 57
    case 57: { playMelody_Data(Melody57, Melody57_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 58
    case 58: { playMelody_Data(Melody58, Melody58_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 59
    case 59: { playMelody_Data(Melody59, Melody59_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 60
    case 60: { playMelody_Data(Melody60, Melody60_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 61
    case 61: { playMelody_Data(Melody61, Melody61_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 62
    case 62: { playMelody_Data(Melody62, Melody62_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 63
    case 63: { playMelody_Data(Melody63, Melody63_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 64
    case 64: { playMelody_Data(Melody64, Melody64_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 65
    case 65: { playMelody_Data(Melody65, Melody65_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 66
    case 66: { playMelody_Data(Melody66, Melody66_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 67
    case 67: { playMelody_Data(Melody67, Melody67_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 68
    case 68: { playMelody_Data(Melody68, Melody68_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 69
    case 69: { playMelody_Data(Melody69, Melody69_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 70
    case 70: { playMelody_Data(Melody70, Melody70_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 71
    case 71: { playMelody_Data(Melody71, Melody71_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 72
    case 72: { playMelody_Data(Melody72, Melody72_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 73
    case 73: { playMelody_Data(Melody73, Melody73_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 74
    case 74: { playMelody_Data(Melody74, Melody74_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 75
    case 75: { playMelody_Data(Melody75, Melody75_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 76
    case 76: { playMelody_Data(Melody76, Melody76_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 77
    case 77: { playMelody_Data(Melody77, Melody77_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 78
    case 78: { playMelody_Data(Melody78, Melody78_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 79
    case 79: { playMelody_Data(Melody79, Melody79_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 80
    case 80: { playMelody_Data(Melody80, Melody80_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 81
    case 81: { playMelody_Data(Melody81, Melody81_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 82
    case 82: { playMelody_Data(Melody82, Melody82_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 83
    case 83: { playMelody_Data(Melody83, Melody83_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 84
    case 84: { playMelody_Data(Melody84, Melody84_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 85
    case 85: { playMelody_Data(Melody85, Melody85_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 86
    case 86: { playMelody_Data(Melody86, Melody86_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 87
    case 87: { playMelody_Data(Melody87, Melody87_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 88
    case 88: { playMelody_Data(Melody88, Melody88_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 89
    case 89: { playMelody_Data(Melody89, Melody89_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 90
    case 90: { playMelody_Data(Melody90, Melody90_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 91
    case 91: { playMelody_Data(Melody91, Melody91_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 92
    case 92: { playMelody_Data(Melody92, Melody92_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 93
    case 93: { playMelody_Data(Melody93, Melody93_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 94
    case 94: { playMelody_Data(Melody94, Melody94_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 95
    case 95: { playMelody_Data(Melody95, Melody95_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 96
    case 96: { playMelody_Data(Melody96, Melody96_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 97
    case 97: { playMelody_Data(Melody97, Melody97_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 98
    case 98: { playMelody_Data(Melody98, Melody98_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 99
    case 99: { playMelody_Data(Melody99, Melody99_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 100
    case 100: { playMelody_Data(Melody100, Melody100_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 101
    case 101: { playMelody_Data(Melody101, Melody101_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 102
    case 102: { playMelody_Data(Melody102, Melody102_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 103
    case 103: { playMelody_Data(Melody103, Melody103_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 104
    case 104: { playMelody_Data(Melody104, Melody104_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 105
    case 105: { playMelody_Data(Melody105, Melody105_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 106
    case 106: { playMelody_Data(Melody106, Melody106_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 107
    case 107: { playMelody_Data(Melody107, Melody107_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 108
    case 108: { playMelody_Data(Melody108, Melody108_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 109
    case 109: { playMelody_Data(Melody109, Melody109_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 110
    case 110: { playMelody_Data(Melody110, Melody110_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 111
    case 111: { playMelody_Data(Melody111, Melody111_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 112
    case 112: { playMelody_Data(Melody112, Melody112_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 113
    case 113: { playMelody_Data(Melody113, Melody113_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 114
    case 114: { playMelody_Data(Melody114, Melody114_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 115
    case 115: { playMelody_Data(Melody115, Melody115_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 116
    case 116: { playMelody_Data(Melody116, Melody116_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 117
    case 117: { playMelody_Data(Melody117, Melody117_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 118
    case 118: { playMelody_Data(Melody118, Melody118_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 119
    case 119: { playMelody_Data(Melody119, Melody119_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 120
    case 120: { playMelody_Data(Melody120, Melody120_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 121
    case 121: { playMelody_Data(Melody121, Melody121_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 122
    case 122: { playMelody_Data(Melody122, Melody122_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 123
    case 123: { playMelody_Data(Melody123, Melody123_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 124
    case 124: { playMelody_Data(Melody124, Melody124_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 125
    case 125: { playMelody_Data(Melody125, Melody125_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 126
    case 126: { playMelody_Data(Melody126, Melody126_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 127
    case 127: { playMelody_Data(Melody127, Melody127_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 128
    case 128: { playMelody_Data(Melody128, Melody128_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 129
    case 129: { playMelody_Data(Melody129, Melody129_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 130
    case 130: { playMelody_Data(Melody130, Melody130_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 131
    case 131: { playMelody_Data(Melody131, Melody131_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 132
    case 132: { playMelody_Data(Melody132, Melody132_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 133
    case 133: { playMelody_Data(Melody133, Melody133_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 134
    case 134: { playMelody_Data(Melody134, Melody134_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 135
    case 135: { playMelody_Data(Melody135, Melody135_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 136
    case 136: { playMelody_Data(Melody136, Melody136_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 137
    case 137: { playMelody_Data(Melody137, Melody137_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 138
    case 138: { playMelody_Data(Melody138, Melody138_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 139
    case 139: { playMelody_Data(Melody139, Melody139_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 140
    case 140: { playMelody_Data(Melody140, Melody140_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 141
    case 141: { playMelody_Data(Melody141, Melody141_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 142
    case 142: { playMelody_Data(Melody142, Melody142_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 143
    case 143: { playMelody_Data(Melody143, Melody143_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 144
    case 144: { playMelody_Data(Melody144, Melody144_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 145
    case 145: { playMelody_Data(Melody145, Melody145_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 146
    case 146: { playMelody_Data(Melody146, Melody146_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 147
    case 147: { playMelody_Data(Melody147, Melody147_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 148
    case 148: { playMelody_Data(Melody148, Melody148_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 149
    case 149: { playMelody_Data(Melody149, Melody149_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 150
    case 150: { playMelody_Data(Melody150, Melody150_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 151
    case 151: { playMelody_Data(Melody151, Melody151_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 152
    case 152: { playMelody_Data(Melody152, Melody152_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 153
    case 153: { playMelody_Data(Melody153, Melody153_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 154
    case 154: { playMelody_Data(Melody154, Melody154_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 155
    case 155: { playMelody_Data(Melody155, Melody155_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 156
    case 156: { playMelody_Data(Melody156, Melody156_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 157
    case 157: { playMelody_Data(Melody157, Melody157_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 158
    case 158: { playMelody_Data(Melody158, Melody158_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 159
    case 159: { playMelody_Data(Melody159, Melody159_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 160
    case 160: { playMelody_Data(Melody160, Melody160_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 161
    case 161: { playMelody_Data(Melody161, Melody161_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 162
    case 162: { playMelody_Data(Melody162, Melody162_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 163
    case 163: { playMelody_Data(Melody163, Melody163_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 164
    case 164: { playMelody_Data(Melody164, Melody164_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 165
    case 165: { playMelody_Data(Melody165, Melody165_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 166
    case 166: { playMelody_Data(Melody166, Melody166_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 167
    case 167: { playMelody_Data(Melody167, Melody167_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 168
    case 168: { playMelody_Data(Melody168, Melody168_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 169
    case 169: { playMelody_Data(Melody169, Melody169_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 170
    case 170: { playMelody_Data(Melody170, Melody170_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 171
    case 171: { playMelody_Data(Melody171, Melody171_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 172
    case 172: { playMelody_Data(Melody172, Melody172_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 173
    case 173: { playMelody_Data(Melody173, Melody173_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 174
    case 174: { playMelody_Data(Melody174, Melody174_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 175
    case 175: { playMelody_Data(Melody175, Melody175_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 176
    case 176: { playMelody_Data(Melody176, Melody176_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 177
    case 177: { playMelody_Data(Melody177, Melody177_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 178
    case 178: { playMelody_Data(Melody178, Melody178_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 179
    case 179: { playMelody_Data(Melody179, Melody179_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 180
    case 180: { playMelody_Data(Melody180, Melody180_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 181
    case 181: { playMelody_Data(Melody181, Melody181_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 182
    case 182: { playMelody_Data(Melody182, Melody182_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 183
    case 183: { playMelody_Data(Melody183, Melody183_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 184
    case 184: { playMelody_Data(Melody184, Melody184_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 185
    case 185: { playMelody_Data(Melody185, Melody185_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 186
    case 186: { playMelody_Data(Melody186, Melody186_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 187
    case 187: { playMelody_Data(Melody187, Melody187_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 188
    case 188: { playMelody_Data(Melody188, Melody188_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 189
    case 189: { playMelody_Data(Melody189, Melody189_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 190
    case 190: { playMelody_Data(Melody190, Melody190_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 191
    case 191: { playMelody_Data(Melody191, Melody191_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 192
    case 192: { playMelody_Data(Melody192, Melody192_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 193
    case 193: { playMelody_Data(Melody193, Melody193_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 194
    case 194: { playMelody_Data(Melody194, Melody194_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 195
    case 195: { playMelody_Data(Melody195, Melody195_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 196
    case 196: { playMelody_Data(Melody196, Melody196_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 197
    case 197: { playMelody_Data(Melody197, Melody197_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 198
    case 198: { playMelody_Data(Melody198, Melody198_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 199
    case 199: { playMelody_Data(Melody199, Melody199_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 200
    case 200: { playMelody_Data(Melody200, Melody200_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 201
    case 201: { playMelody_Data(Melody201, Melody201_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 202
    case 202: { playMelody_Data(Melody202, Melody202_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 203
    case 203: { playMelody_Data(Melody203, Melody203_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 204
    case 204: { playMelody_Data(Melody204, Melody204_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 205
    case 205: { playMelody_Data(Melody205, Melody205_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 206
    case 206: { playMelody_Data(Melody206, Melody206_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 207
    case 207: { playMelody_Data(Melody207, Melody207_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 208
    case 208: { playMelody_Data(Melody208, Melody208_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 209
    case 209: { playMelody_Data(Melody209, Melody209_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 210
    case 210: { playMelody_Data(Melody210, Melody210_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 211
    case 211: { playMelody_Data(Melody211, Melody211_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 212
    case 212: { playMelody_Data(Melody212, Melody212_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 213
    case 213: { playMelody_Data(Melody213, Melody213_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 214
    case 214: { playMelody_Data(Melody214, Melody214_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 215
    case 215: { playMelody_Data(Melody215, Melody215_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 216
    case 216: { playMelody_Data(Melody216, Melody216_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 217
    case 217: { playMelody_Data(Melody217, Melody217_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 218
    case 218: { playMelody_Data(Melody218, Melody218_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 219
    case 219: { playMelody_Data(Melody219, Melody219_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 220
    case 220: { playMelody_Data(Melody220, Melody220_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 221
    case 221: { playMelody_Data(Melody221, Melody221_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 222
    case 222: { playMelody_Data(Melody222, Melody222_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 223
    case 223: { playMelody_Data(Melody223, Melody223_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 224
    case 224: { playMelody_Data(Melody224, Melody224_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 225
    case 225: { playMelody_Data(Melody225, Melody225_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 226
    case 226: { playMelody_Data(Melody226, Melody226_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 227
    case 227: { playMelody_Data(Melody227, Melody227_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 228
    case 228: { playMelody_Data(Melody228, Melody228_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 229
    case 229: { playMelody_Data(Melody229, Melody229_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 230
    case 230: { playMelody_Data(Melody230, Melody230_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 231
    case 231: { playMelody_Data(Melody231, Melody231_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 232
    case 232: { playMelody_Data(Melody232, Melody232_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 233
    case 233: { playMelody_Data(Melody233, Melody233_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 234
    case 234: { playMelody_Data(Melody234, Melody234_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 235
    case 235: { playMelody_Data(Melody235, Melody235_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 236
    case 236: { playMelody_Data(Melody236, Melody236_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 237
    case 237: { playMelody_Data(Melody237, Melody237_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 238
    case 238: { playMelody_Data(Melody238, Melody238_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 239
    case 239: { playMelody_Data(Melody239, Melody239_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 240
    case 240: { playMelody_Data(Melody240, Melody240_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 241
    case 241: { playMelody_Data(Melody241, Melody241_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 242
    case 242: { playMelody_Data(Melody242, Melody242_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 243
    case 243: { playMelody_Data(Melody243, Melody243_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 244
    case 244: { playMelody_Data(Melody244, Melody244_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 245
    case 245: { playMelody_Data(Melody245, Melody245_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 246
    case 246: { playMelody_Data(Melody246, Melody246_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 247
    case 247: { playMelody_Data(Melody247, Melody247_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 248
    case 248: { playMelody_Data(Melody248, Melody248_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 249
    case 249: { playMelody_Data(Melody249, Melody249_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 250
    case 250: { playMelody_Data(Melody250, Melody250_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 251
    case 251: { playMelody_Data(Melody251, Melody251_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 252
    case 252: { playMelody_Data(Melody252, Melody252_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 253
    case 253: { playMelody_Data(Melody253, Melody253_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 254
    case 254: { playMelody_Data(Melody254, Melody254_Length, tempo); return; }
  #endif
  #if NUMBER_OF_MELODIES > 255
    case 255: { playMelody_Data(Melody255, Melody255_Length, tempo); return; }
  #endif
`Actual main code`
#include <HardwareSerial.h>
#include <Arduino.h>
#include <Wire.h>
extern HardwareSerial Serial1;
extern HardwareSerial Serial2;
char incomingByte;
char incomingByte1;
//Speaker
int Swing = 16;
int RedLED = 12;
//L293D
//Swing Motor (Big motor)
const int motorPin1  = 5;  // Pin 14 of L293
const int motorPin2  = 6;  // Pin 10 of L293
//Toy Motor (Small Motor)
const int motorPin3  = 10; // Pin  7 of L293
const int motorPin4  = 9;  // Pin  2 of L293
int EN1 = 3;                 // Pin 1 of L293D IC, D6 Pin of NodeMCU (controls the speed)
//SPEAKER
// Pin to which an 8 Ohm speaker is connected (use a 150 - 220 Ohm resistor)
  //Set speaker outputs
  pinMode(tonePin, OUTPUT);
  //Set motor pins as outputs
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
  pinMode(EN1, OUTPUT); //Where the motor is connected to for speed control
  Serial2.begin(115200);
  Serial.println("Ready for commands");
  while (Serial2.available() > 1) {
    // read the incoming byte:
    incomingByte = Serial2.read();
    incomingByte1 = Serial2.read();
    Serial.print ("Received data = ");
    Serial.print(int(incomingByte) , DEC);
    Serial.println(int(incomingByte1) , DEC);
  if (incomingByte == 0) { // Turn the swing ON
    Serial.println ("Command: ten");
    digitalWrite(Swing, HIGH);
  if (incomingByte == 1) { // Turn the swing off
    Serial.println ("Command: Two");
    digitalWrite(Swing, LOW);
  if (incomingByte == 2) { // Turn the music on
    Serial.println ("Command: Three");
// Track 0 - Piano
      noTone(tonePin);
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  if (incomingByte == 3) { // Turn the music off
    Serial.println ("Command: Four");
    digitalWrite(Speaker, LOW);
  if (incomingByte == 4) { // Make swing faster
    Serial.println ("Command: Five");
    digitalWrite(RedLED, 255);
  if (incomingByte == 5) { // Make the swing slower
    Serial.println ("Command: Six");
    digitalWrite(RedLED, 0);
 if (incomingByte == 6) { // Turn swinging motion on
    Serial.println ("Command: Seven");
    digitalWrite(motorPin1, HIGH);
    digitalWrite(motorPin2, LOW);
  if (incomingByte == 7) { // Turn swinging motion off
    Serial.println ("Command: Eight");
    digitalWrite(motorPin1, LOW);
  if (incomingByte == 9) { //Turn mobile toys off
    Serial.println ("Command: one");
    digitalWrite(motorPin3, HIGH);
    digitalWrite(motorPin4, LOW);
  if (incomingByte == 10) { // Turn the mobile toys on
    Serial.println ("Command: Nine");
    digitalWrite(motorPin3, LOW);
Your code has two setup and two loops.
do yourself a favour and please read How to get the best out of this forum and modify (edit) your post accordingly (including code tags and necessary documentation for your ask).
I edited it, What do you mean by two setups and loops?
Where?
I guess I got lost in the scrolling and did not see the separation between the two codes.
where does your loop starts and stops? (look at the {})
You have some code in your .pdf. Where does that come in? You have some code in this thread. Is there anything which combines the two of them? If so post it. Or if not, which code are you having trouble with?
Steve
In a new reply, please post just the code causing you trouble, using code tags.
I am trying to take the code below and make it into and if statement. Meaning if i turn the speaker on the song will run and if i turn the speaker off the song will stop. I want to trasnform it to work in a
if (incomingByte == 7) { // Turn Music on
    digitalWrite(speaker, HIGH);
static const uint8_t tonePin = 4;
  // 0 - Piano
// go any further.
// Melody Data
//  NOTE_C_4(2)
// Track 0 - Piano
/** Play a melody.
      noTone(tonePin);
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
  #endif
once a melody is selected, this code runs:
  for (uint16_t  x = 0; x < MelodyLength; x++)
    if ((data & 0xF) == 0xF)
      noTone(tonePin);
      uint16_t Freq = pgm_read_word(&Freq8[data & 0xF]) / ( 1 << (8 - (data >> 4 & 0xF)) );
    int16_t Duration = data >> 8;
    while (Duration--) delay(tempo);
you can't stop it the way it is written as it does not listen to the Serial input (and code might be Locked in the delay(tempo))
is there a way to make it listen to serial port
Sure you could check the Serial port in that function - I assume the pauses are quite short so you would not see much lag
I thought you said it doesnt listen to the serial port
it does not AT THE MOMENT.
you could add it by modifying the function :slight_smile:
assuming the data is really sent as binary and 7 is the number you get (not the character '7') then something like this might work.
    if (Serial.peek() == 7) {Serial.read(); break;} // <<=== stop playing if we received 7
      noTone(tonePin);
Where would this go in my original code and what about all the rest of the code that was provided like the actual song?
Do you understand any of that code ?
Honestly, no
I really just need one song to play from my speaker and be able to tell it to turn on and off
Is it possible to, to make a speaker turn on and off by my voice
Sure with the limits of the components you use - and the possibility that your voice will be covered by the music if the microphone is picking up that sound and not able to filter it out.
Lots of research went into HomePod, Alexa or Google and other voice enabled speakers
If you want something that works well and is nice looking and don’t want to spend tons of hours in learning all the underlying technologies then buy one of those.
I need this for a school project.
Is there a way maybe to just produce a little tune when i tell the speaker to turn on.
by an MP3 board like the DFPlayer Mini. It's cheap and you can send commands to play pause etc
