Hi, I am a student whose new to Arduino, I have been tasked to built a Project using Arduino, and I am thinking to built a Speaker with Bluetooth and Motion Sensor Built-in.
Things I got:
Arduino Uno R3 ATmega328P DIP
HC-05 Bluetooth Wireless Module Arduino Raspberry Pi
HC-SR501 PIR Motion Sensor Module Arduino Raspberry Pi
DFPlayer Mini MP3 Module
LCD 84x84 Nokia 5110 Module Blue Blacklight for Arduino
Toshiba SPEAKER 42X75- 8OHM 5W SPK-1536AR
Resistor Metal film 3W 10K
LED Osram 10mm P-B [ putih nyala Biru terang ]
Resistor R1/4W 330 ohm [ 100 pcs ] Metal film 1%
Breadboard MB-102
Tactile Switch Push Button 12x12x7.3mm
Male-Female Breadboard Arduino Wire Bread Board Cable AB69
Male-Male Breadboard Arduino Wire Bread Board Cable AB70
Battery Klip Clip Snap 2.1x5.5mm Male DC Plug to 9V Battery AF22
USB Cable
Ideas:
I am thinking to control the Arduino based on motion sensor. If there's a motion nearby, the speaker turns on and play random music by reading the SD Card from DFPlayer Mini MP3 Module, and turns off when there's no motion nearby for about a minute.
I am thinking to select the music from DFPlayer Mini MP3 Module using the Taticle Switch Push Button (one for next and the another one for back)
I am thinking to play music via bluetooth (e.g Android phone)
Questions:
Is there any "Things I got" that I must get rid off or is there any "Things I got" that were left behind?
At the moment, I've no experience whatsoever using Arduino, perhaps, I am able to install the components. but I am completely black out about the programming section, I am really desperate and need to be helped on programming section, if you don't mind, of course.
