I'm trying to run several operations in series. After being triggered, I want to run a speaker, then a servo, then turn on an LED.
My sketch works fine EXCEPT it will not play the WAV file and run the servo in sequence. If everything is connected, it will play the WAV, and turn on the LED after the correct delays (so it is going through the servo loop) but will not run the servo in between.
If I comment out the WAV line, the servo works fine, even without disconnecting the speaker. I tried connecting the servo to a separate power supply and the result is the same.
Any ideas why this would be?
#include <Servo.h>
#include <pcmConfig.h>
#include <pcmRF.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 10 //using digital pin 10 on arduino nano 328
#include <ezOutput.h>
#include <SPI.h>
#include <SD.h>
File myFile;
int led_pin = 3;
int red_pin = 6;
int eye_pin = 5; //Eye lights
int Button = 2;
int buttonState = 0; // variable for reading the pushbutton status
unsigned long pushtime = 5000;
unsigned long initial = 0;
unsigned long current = 0;
unsigned long duration = 0;
int A = 2;
TMRpcm tmrpcm; // create a speaker object for use in this sketch
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(3); // attaches the servo on pin 9 to the servo object
pinMode(led_pin, OUTPUT); // Declare the LED as an output
pinMode(red_pin, OUTPUT); // Declare the LED as an output
pinMode(eye_pin, OUTPUT); // Declare the LED as an output
pinMode(Button, INPUT);
Serial.begin(9600); //print rate
tmrpcm.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
if (!SD.begin(SD_ChipSelectPin)) { // see if the card is present and can be initialized:
return; // don't do anything more if not
tmrpcm.volume(10);
A = 1;
buttonState = digitalRead(Button); // read the state of the pushbutton value:
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (A != 2) {
digitalWrite(eye_pin, LOW);
if (buttonState == HIGH) {
initial = millis();
duration = 0;
tmrpcm.play("service.wav");
delay(1000); //Pause for 1 second to make sure the button is not still pushed
while (duration < pushtime) { //During the Pushtime duration after the trigger:
duration = (millis() - initial); //time since button was first pushed
if (buttonState == HIGH) { //If the button is pushed a 2nd time
delay(100);
if (A == 2) { //If status was DOWN (A=2)
A = 1;
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15);
//Serial.println("RAISED"); //status
else { //If status was UP (A=1)
A = 2;
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
delay(15); // waits 15ms for the servo to reach the position
//Serial.println("LOWERED"); //status
// delay(500);
digitalWrite(eye_pin, HIGH);
Serial.println(duration); //time record
delay(100);
