Speakjet/Servo Problem
Hello, I’m relatively new to using the Arduino platform. As a high school student, I have been tasked to create a program that will allow me to use the Speakjet chip as well as running a servo in time with the “words.” I have already been experimenting with the program and I have completed the hardwiring. I’ve definitely encountered a few problems. I have read that using the Speakjet chip can lead to word overflow if you were to use too much in a phrase. When alone, my program for the phrase I want the robot to say plays fine. Also, the servo program I have made works like I need it to. The problem I’m facing is when I add both elements of the program together, it has problems working. The concept works and for the first three phrases both the motor and speech work like I need them to. However, if I add the rest of my program, it starts to go off course. In addition, after the first loop play through it starts to add in random noises and slur its phrases. I’ve added in caps for noise reduction near the servo and tried to take the program out of the loop completely.
Any help or advice would be appreciated. My program is listed below; please remember I am a novice at this.
// set up a new software serial port
//rxPin: the pin on which to receive serial data
//txPin: the pin on which to transmit serial data
#include <SoftwareSerial.h>
#include <Servo.h>
#define txPin 2
#define rxPin 3
// set up the SoftwareSerial port to connect to the SpeakJet
SoftwareSerial SpeakJetSerial = SoftwareSerial(rxPin, txPin);
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
int val; // variable to read the value from the analog pin
myservo.attach(5); // attaches the servo on pin 9 to the servo object
// define pin modes for tx, rx pins:
//pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
SpeakJetSerial.begin(9600);
// char array holding the 'lets make robots' string we want to speak
char SayIt[] = {140,154};
SpeakJetSerial.println(SayIt); // send it to the SpeakJet
val = 25; // reads the value of the potentiometer (value between 0 and 1023)
myservo.write(val); // sets the servo position according to the scaled value
delay(600); // waits for the servo to get there
char SayIt2[] = {157,183};
SpeakJetSerial.println(SayIt2); // send it to the SpeakJet
val = 100; // reads the value of the potentiometer (value between 0 and 1023)
delay(500); // waits for the servo to get there
char SayIt3[] = {132,166};
SpeakJetSerial.println(SayIt3); // send it to the SpeakJet
val = 50; // reads the value of the potentiometer (value between 0 and 1023)
// infinite do-nothing loop
char SayIt4[] = {128,153};
SpeakJetSerial.println(SayIt4); // send it to the SpeakJet
delay(10000);
Please edit your post to add code tags so your code
// looks like this please...
Could you explain what you're intending the sketch to do? Assume I don't know anything about anything except what an Arduino is.
You are calling a function that expects a NULL terminated array of chars with an array that is NOT null terminated. Good luck getting consistent results with that.
My exact goal for the project is to make the servo move in time with each word it speaks. I'm in the process of fabricating a face that has a moveable jaw controlled by the servos. The only problem i have lies in the programming because I'm unfamiliar with it altogether. And by null, what exactly do you mean?
SayIt2[3] = '\0'; // NULL terminate the array.
You need, of course, to size the array correctly.
It turns out my problem was in the char SayIt[] line. I didn't understand at first what you meant by Null, but it turns out that that was where my problem was. Thanks!
