Special character led matrix with shift registers
Thanks to the author of this program!
Scrolling text display for YFRobot 8x8 Dot Matrix display (controller with dual serial 74HC595 chips)
Author: Andy Qua
Date: 26th April 2015
int dataPin = 10; // The Serial Data Pin to the Shift Register
int latchPin = 8; // The Latch Pin to the Shift Register
int clockPin = 7; // The Clock Pin to the Shift Register
// Basic alphabet
byte letters[][6] = {
{ 0x7F, 0x88, 0x88, 0x88, 0x7F, 0x00}, // A
{ 0xFF, 0x91, 0x91, 0x91, 0x6E, 0x00}, // B
{ 0x7E, 0x81, 0x81, 0x81, 0x42, 0x00}, // C
{ 0xFF, 0x81, 0x81, 0x42, 0x3C, 0x00}, // D
{ 0xFF, 0x91, 0x91, 0x91, 0x81, 0x00}, // E
{ 0xFF, 0x90, 0x90, 0x90, 0x80, 0x00}, // F
{ 0x7E, 0x81, 0x89, 0x89, 0x4E, 0x00}, // G
{ 0xFF, 0x10, 0x10, 0x10, 0xFF, 0x00}, // H
{ 0x81, 0x81, 0xFF, 0x81, 0x81, 0x00}, // I
{ 0x06, 0x01, 0x01, 0x01, 0xFE, 0x00}, // J
{ 0xFF, 0x18, 0x24, 0x42, 0x81, 0x00}, // K
{ 0xFF, 0x01, 0x01, 0x01, 0x01, 0x00}, // L
{ 0xFF, 0x40, 0x30, 0x40, 0xFF, 0x00}, // M
{ 0xFF, 0x40, 0x30, 0x08, 0xFF, 0x00}, // N
{ 0x7E, 0x81, 0x81, 0x81, 0x7E, 0x00}, // O
{ 0xFF, 0x88, 0x88, 0x88, 0x70, 0x00}, // P
{ 0x7E, 0x81, 0x85, 0x82, 0x7D, 0x00}, // Q
{ 0xFF, 0x88, 0x8C, 0x8A, 0x71, 0x00}, // R
{ 0x61, 0x91, 0x91, 0x91, 0x8E, 0x00}, // S
{ 0x80, 0x80, 0xFF, 0x80, 0x80, 0x00}, // T
{ 0xFE, 0x01, 0x01, 0x01, 0xFE, 0x00}, // U
{ 0xF0, 0x0C, 0x03, 0x0C, 0xF0, 0x00}, // V
{ 0xFF, 0x02, 0x0C, 0x02, 0xFF, 0x00}, // W
{ 0xC3, 0x24, 0x18, 0x24, 0xC3, 0x00}, // X
{ 0xE0, 0x10, 0x0F, 0x10, 0xE0, 0x00}, // Y
{ 0x83, 0x85, 0x99, 0xA1, 0xC1, 0x00}, // Z
{ 0x06, 0x29, 0x29, 0x29, 0x1F, 0x00}, // a
{ 0xFF, 0x09, 0x11, 0x11, 0x0E, 0x00}, // b
{ 0x1E, 0x21, 0x21, 0x21, 0x12, 0x00}, // c
{ 0x0E, 0x11, 0x11, 0x09, 0xFF, 0x00}, // d
{ 0x0E, 0x15, 0x15, 0x15, 0x0C, 0x00}, // e
{ 0x08, 0x7F, 0x88, 0x80, 0x40, 0x00}, // f
{ 0x30, 0x49, 0x49, 0x49, 0x7E, 0x00}, // g
{ 0xFF, 0x08, 0x10, 0x10, 0x0F, 0x00}, // h
{ 0x00, 0x00, 0x5F, 0x00, 0x00, 0x00}, // i
{ 0x02, 0x01, 0x21, 0xBE, 0x00, 0x00}, // j
{ 0xFF, 0x04, 0x0A, 0x11, 0x00, 0x00}, // k
{ 0x00, 0x81, 0xFF, 0x01, 0x00, 0x00}, // l
{ 0x3F, 0x20, 0x18, 0x20, 0x1F, 0x00}, // m
{ 0x3F, 0x10, 0x20, 0x20, 0x1F, 0x00}, // n
{ 0x0E, 0x11, 0x11, 0x11, 0x0E, 0x00}, // o
{ 0x3F, 0x24, 0x24, 0x24, 0x18, 0x00}, // p
{ 0x10, 0x28, 0x28, 0x18, 0x3F, 0x00}, // q
{ 0x1F, 0x08, 0x10, 0x10, 0x08, 0x00}, // r
{ 0x09, 0x15, 0x15, 0x15, 0x02, 0x00}, // s
{ 0x20, 0xFE, 0x21, 0x01, 0x02, 0x00}, // t
{ 0x1E, 0x01, 0x01, 0x02, 0x1F, 0x00}, // u
{ 0x1C, 0x02, 0x01, 0x02, 0x1C, 0x00}, // v
{ 0x1E, 0x01, 0x0E, 0x01, 0x1E, 0x00}, // w
{ 0x11, 0x0A, 0x04, 0x0A, 0x11, 0x00}, // x
{ 0x00, 0x39, 0x05, 0x05, 0x3E, 0x00}, // y
{ 0x11, 0x13, 0x15, 0x19, 0x11, 0x00}, // z
{ 0x00, 0x41, 0xFF, 0x01, 0x00, 0x00}, // 1
{ 0x43, 0x85, 0x89, 0x91, 0x61, 0x00}, // 2
{ 0x42, 0x81, 0x91, 0x91, 0x6E, 0x00}, // 3
{ 0x18, 0x28, 0x48, 0xFF, 0x08, 0x00}, // 4
{ 0xF2, 0x91, 0x91, 0x91, 0x8E, 0x00}, // 5
{ 0x1E, 0x29, 0x49, 0x89, 0x86, 0x00}, // 6
{ 0x80, 0x8F, 0x90, 0xA0, 0xC0, 0x00}, // 7
{ 0x6E, 0x91, 0x91, 0x91, 0x6E, 0x00}, // 8
{ 0x70, 0x89, 0x89, 0x8A, 0x7C, 0x00}, // 9
{ 0x7E, 0x89, 0x91, 0xA1, 0x7E, 0x00}, // 0
{ 0x60, 0x80, 0x8D, 0x90, 0x60, 0x00}, // ?
{ 0x00, 0x00, 0xFD, 0x00, 0x00, 0x00}, // !
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // SPACE
// character to letter mapping
String letterPositions = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890?!";
// The database for the text to scroll
byte *textBytes;
int nrLetters = 0;
int columnPositions[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
pinMode(dataPin, OUTPUT); // Configure Digital Pins
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
// Text = Anything you want
loadString( " Smiley " );
void loadString( String text )
// Build up byte array
nrLetters = text.length();
// Allocate memory for byte array
textBytes = (byte *)malloc(nrLetters * 6 * sizeof(byte));
int pos = 0;
for ( int i = 0 ; i < nrLetters ; ++i )
int chPos = letterPositions.indexOf( text[i] );
if ( chPos == -1 )
continue;
for ( int j = 0 ; j < 6 ; ++j )
textBytes[pos++] = letters[chPos][j];
for ( int p = 0 ; p < (nrLetters * 6) ; p++ )
int rowVal = 0;
// Change repeat to vary the speed of the scrolling text
for (int repeat = 0; repeat < 50; repeat++ )
for ( int row = 0 ; row < 8 ; ++row )
rowVal = textBytes[p + row];
// For some reason, columnPositions are set sanely (e.g. 1,2,4,8,16,32,64,128)
// BUT the row values are inverted - so a 1 means off and a 0 is on!
// so we invert the bits in the rowVal.
writeOutput(~rowVal, columnPositions[row]);
void writeOutput( int rowVal, int col )
digitalWrite(latchPin, LOW); // Pull latch LOW to send data
shiftOut(dataPin, clockPin, MSBFIRST, rowVal); // Send the row data byte
shiftOut(dataPin, clockPin, MSBFIRST, col); // Send the column data byte
digitalWrite(latchPin, HIGH); // Pull latch HIGH to finish sending data
Hi
I found this code on the internet which displays a message on a led matrix. But I also want to be able to display special characters (suppose like a heart ). It is possible to do this?
yeah, just build the right bitmap and add it to the array, it needs to have an ASCII counterpart apparently in the letterPositions String (or replace a glyph you don't use)
J-M-L:
So I add the code for smile,
{0x3c,0x42,0x95,0xa1,0xa1,0x95,0x42,0x3c}
then in letterPositions after! I write smiley (smile face) for example, but I get the error 'too many initializers for' byte [6] '. I'm not quite sure where I should change the program, probably byte letters would be [] [8], but there are some for loops that are ambiguous to me.
cristian10001:
Error messages generally include the line number in which they occur. Aren't you trying to stuff 8 bytes into 6?
indeed the glyphs are represented on 6 bytes
and your {0x3c, 0x42, 0x95, 0xa1, 0xa1, 0x95, 0x42, 0x3c}requires 8 bytes... you need a new drawing fitting on 6 bytes
