Special Character on 16x2 LCD-Display
Hello together
Im new to the Arduino Community and Programming in general.
I want to write some special characters on an LCD-Display. I already wrote the Programm below, it works to simply write a text on the display.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
;lcd.begin(15,2)
;lcd.clear()
;lcd.clear()
;lcd.setCursor(1,1)
;lcd.print("insert text here")
;delay(4000)
;lcd.clear()
Now Id like to write something with the following scheme:
B00000
B00000
B00000
B00000
B00000
B00000
B00000
B00000
what do i have to insert instead of "insert text here" in the programm?
Please help me :slight_smile:
The liquid crystal library has an example called CustomCharacter that shows how to create and use custom characters. Note that you can have only 8 custom characters. What is with the semicolons before the code lines? Not right at all. should be like:
lcd.write(2);
semicolons end the line not start it.
Well thanks, you really helped me. About de semicolons: Sorry didnt know it :blush:
Laura_95:
Have you not looked at any examples of Arduino code? I would strongly suggest you have a look through several examples and maybe even try a few of the simple ones before you try to go any further. Otherwise this may become intensly frustrating. The compiler is very picky about how you write things.
Laura_95:
B00000
B00000
B00000
B00000
B00000
B00000
B00000
B00000
That's no "special" character, the coding is for a "space" character and you can simply send a space with:
Serial.print(' ');
If you want to create data for real "special" characters, perhaps try:
https://omerk.github.io/lcdchargen/
(At the bottom of that page there is also some demonstration code.)
