Special Status Code 248
I'm trying to interface Arduino Uno with ADXL345 (Accelerometer) Over I2C Protocol. The register TWSR in the ATmega328p controller which supposed to give a set of predefined codes, is showing a status code 248.
I had searched for it but did not find any satisfactory answer for my problem. I am following the procedure mentioned in the Datasheet of ADXL345.
#define TWSR (*((volatile unsigned int *) 0xB9))
#define TWAR (*((volatile unsigned int *) 0xBA))
#define TWDR (*((volatile unsigned int *) 0xBB))
#define TWCR (*((volatile unsigned int *) 0xBC))
float X_Axis, Y_Axis, Z_Axis;
int x;
  Serial.begin(9600); //Serial Communication.
  Serial.println("ADXL345 Interface.");
  TWSR=0x00;
  Start();
  SLA_Write();
  X_Axis=REGAddress_X0();
  Serial.println(" Partial X output X0=");
  Serial.println(X_Axis);
void Start()
 Start: //label
  TWCR=0xA4;
  delayMicroseconds(0.6); //Delay,As per mentioned in ADXL345 Datasheet.
  Serial.print("TWSR in START Function:");
  Serial.println(TWSR);
  if(0x08 != TWSR)
    goto Start;  // jump to label.
   delayMicroseconds(1.2); //t3-t5 Delay ADXL345 Datasheet.
void SLA_Write()
  SLA_Write:
  //delayMicroseconds(0.3);
  TWDR=0xA6;
  delayMicroseconds(1.6); //t2+t6+t5 (setup+hold+SCL high) time; ADXL345 Datasheet.
  TWCR=0x84;
  Serial.print("TWSR in SLAWrite Function:");
  switch(TWSR)
    case 0x18: Serial.println("SLA+W has been transmitted;ACK has been received 0x18");
    case 0x20: Serial.println("SLA+W has been transmitted;ACK has been received");
                Start();
                goto SLA_Write;
    case 0x38: Serial.println("Arbitration lost in SLA+W ordata bytes");
                Start();
                goto SLA_Write;
int REGAddress_X0()
  REGAddress_X0:   // Label
  TWDR=0x32; // X0 Register-ADXL345 Datasheet.
  if(0x28 != TWSR)
      goto REGAddress_X0;   // jump to label.
  //delayMicroseconds(1.6);  //t2+t6+t5 (setup+hold+SCL high) time; ADXL345 Datasheet.
  Start();
  delayMicroseconds(0.6); // Repeated start setup time delay t7. ADXL345 Datasheet.
  TWDR= 0xA7; //SLA+Read ATmega 328p Datashet & ADXL345 Datasheet.
  TWCR= 0x84; // Clearing INT Flag. ATmega 328p Datasheet.
  switch(TWSR)
    case 0x40: Serial.println("SLA+W has been transmitted;ACK has been received 0x40");
    case 0x48: Serial.println("SLA+W has been transmitted;NOT ACK has been received 0x48");
               Start();
               SLA_Write();
               goto REGAddress_X0;
    case 0x38: Serial.println("Arbitration lost in SLA+W ordata bytes 0x38");
               Start();
               SLA_Write();
               goto REGAddress_X0;
    return TWDR;
The code is partial. There are two registers for each of the 3 Axis (ie X0 X1, Y0 Y1, Z0 Z1). Right now I am trying to get values from X0 register.
Can anyone help me out with a proper solution?
Check out Table 26-7 of the datasheet, it is on page 289.
