or it has random output when the finger is removed.
That's the one.
When the finger is removed the wiper on the softpot is floating, therefore all the analogue input picks up is noise, hence the jittering.
The simple cure is to add a pull down resistor. About 100K to ground should do it.
This means when you remove your finger you will get a reading of close to zero. You might want to add software that stops the servo from going back to zero at that point.
Note if it is a circular softpot you can short the two ends together if you are not careful where you press.
But still I am unable to retain the position of servo while i remove the finger from softpot :~
well first of all Is it possible to retain the position while we remove finger from softpot as it's resistance comes to zero ??
My applications is I need to move track with softpot (first i used to adjust it with 10k standard knob pot), Now to adjust the position of track, I want to use softpot (slide finger front to move track to front most position)
Can you write your code to "ignore" the pot reading you get when your finger is not on the softpot?
What I'm thinking is something like this pseudo code
if (softPotVal > noFingerVal) {
// use the value as normal
// save it in a variable for use elsewhere
// if the IF test fails the saved value won't change
Yes ignoring the readings is a good simple method.
It has the disadvantage of having a range of the pot where even if you are pressing is ignored.
They way round that is to detect when the finger iss off, this is a bit more involved.
Wire the ends of the pot to two digital outputs. Take two readings one with one output high and the other low, and another with these reversed. The two readings should be the complement of each other if a finger is pressing. That is
Reading1 should equal 1023 - Reading 2
It won't exactly be equal there will be a bit of jitter but take cair of that in the code.
Grumpy_Mike:
Yes ignoring the readings is a goo simple method.
This is just a follow up to gain more information ...
I presume you mean "halving" and I don't understand why you say that. I had assumed you would just lose a little bit at one end of the range.
No I mean having.
If it reads zero when your finger is off and that is the value you ignore. Then it will also ignore zero when your finger is on and you slid down to the bottom.
No I mean having.
Thanks, sorry for misunderstanding. What you say about getting zero when you touch that point and when you don't touch anything is what I was assuming. I think I would be happy to waste (say) the bottom 5% of the range in return for the simplicity.
To retain the position of motor after removing the finger from soft pot I tried one code mentioned below. But its not working
can anybody suggest any correction in it?
#include <Servo.h>
Servo myservo;
int potpin = 0;
int softPotVal;
int noFingerVal;
int val;
One thing that may also help you is to put a capacitor between the wiper and the ground. It should keep your value. But, they also discharge with time. The rate of discharging can be diminued by taking capacitor with bigger value.
