Hello All,
I am new to the forum and currently seeking advice/tweak suggestions on my project. I am building a proximity sensor mounted to a moving object. I'd like to have the Arduino and Xbee's communicate instantaneously at 5 - 10mph . I currently have the code written for PM not Analog and wonder if that's the key element in the speed factor. The current speed sweet spot is around 1.5 seconds.
As I am also new to coding, I am a little lost when coding to Analog.
Here are the Items being used:
2x - http://store.arduino.cc/product/A000065
2x - http://store.arduino.cc/product/A000066
2x - https://www.sparkfun.com/products/8665
1x - PING))) Ultrasonic Distance Sensor - Parallax
1x - MB7369 HRXL-MaxSonar-WRM – MaxBotix (as a backup)
Here's my code for both the receiver and the sensor:
// Arduino_1_leds
int LED0 = 12;
int LED1 = 11;
int LED2 = 10;
int LED3 = 9;
int LED4 = 8;
int LED5 = 7;
int LED6 = 6;
int blink_state = 0;
char val = ' ';
void setup(){
pinMode(LED0,OUTPUT);
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
pinMode(LED3,OUTPUT);
pinMode(LED4,OUTPUT);
pinMode(LED5,OUTPUT);
pinMode(LED6,OUTPUT);
delay(2000);
//light test to make sure all LEDs are fuctioning
LED_on();
delay(3000);
LED_off();
delay(100);
LED_on();
delay(250);
LED_off();
Serial.print("LED test done, starting to reading sensor output ");
void loop(){
if (Serial.available() > 0) {
val = Serial.read(); //query output from sensor
Serial.print("value from sensor: ");
Serial.println(val);
//Serial.println (" case");
if (val == '0'){
Serial.println(" case 0 ");
case0();
if (val == '1'){
Serial.println(" case 1 ");
case1();
if (val == '2'){
Serial.println(" case 2 ");
case2();
if (val == '3'){
Serial.println(" case 3 ");
case3();
if (val == '4'){
Serial.println(" case 4 ");
case4();
if (val == '5'){
Serial.println(" case 5 ");
case5();
if (val == '6'){
Serial.println(" case 6 ");
case6();
if (val == '7'){
Serial.println(" case 7 ");
case7();
if (val == '8'){
Serial.println(" case 8 ");
case8();
Serial.println("pause .35 seconds");
delay(350); // seconds between readings
else{
Serial.println("Serial input not working...probably Janneh's fault");
delay(350); //350 milliseconds yields no delay with transmission set at 1000
void case0(){
digitalWrite(LED0,LOW);
digitalWrite(LED1,LOW);
digitalWrite(LED2,LOW);
digitalWrite(LED3,LOW);
digitalWrite(LED4,LOW);
digitalWrite(LED5,LOW);
digitalWrite(LED6,LOW);
blink_state = 0;
void case1(){
digitalWrite(LED0,HIGH);
blink_state = 0;
void case2(){
digitalWrite(LED1,HIGH);
blink_state = 0;
void case3(){
digitalWrite(LED2,HIGH);
blink_state = 0;
void case4(){
digitalWrite(LED3,HIGH);
blink_state = 0;
void case5(){
digitalWrite(LED4,HIGH);
blink_state = 0;
void case6(){
digitalWrite(LED5,HIGH);
blink_state = 0;
void case7(){
digitalWrite(LED6,HIGH);
blink_state = 0;
void case8(){
//delay(500);
//digitalWrite(LED0,LOW);
//digitalWrite(LED1,LOW);
//digitalWrite(LED2,LOW);
//digitalWrite(LED3,LOW);
//digitalWrite(LED4,LOW);
//digitalWrite(LED5,LOW);
//digitalWrite(LED6,LOW);
//delay(500);
void LED_on(){
void LED_off(){
// Arduino_2_sensor
// this constant won't change. It's the pin number
const int pingPin = 7;
void setup(){
// initialize serial communication:
Serial.println('0'); //turn on the LED
Serial.println('1');//turn off the LED
Serial.println('2'); //turn on the LED
Serial.println('3');//turn off the LED
Serial.println('4'); //turn on the LED
Serial.println('5');//turn off the LED
Serial.println('6'); //turn on the LED
Serial.println('7');//turn off the LED
Serial.println('8');//turn off the LED
void loop(){
// establish variables for duration of the ping and the value
long duration, inches, cm, value;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT) ;
digitalWrite(pingPin, LOW) ; // init sensor to ensure clean HIGH pulse
delayMicroseconds(2) ;
digitalWrite(pingPin, HIGH) ; // make the sensor send a pulse
delayMicroseconds(5) ;
digitalWrite(pingPin, LOW) ; // Set LOW again
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT) ; // Get ready to capture the duration of the resulting pulse
duration = pulseIn(pingPin, HIGH) ;
if (duration == 0) {
//DEBUG
//Serial.println ("No Pulse received from the sensor") ;
else{
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
value = inches;
//DEBUG
//Serial.print ("Distance : ") ;
//Serial.print(value);
//Serial.println (" inches");
if ((value <=140) && (value >= 1)){
if((value > 43)){
else if ((value <=39) && (value > 35)){
else if ((value <=35) && (value > 31)){
else if ((value <=31) && (value > 27)){
else if ((value <=27) && (value > 23)){
else if ((value <=23) && (value > 19)){
else if ((value <=19) && (value > 15)){
else if ((value <=15) && (value > 11)){
else{
delay(1500); //seems to be working better than 1000, need to find sweet spot
long Convert_Time_Space(const long fnDuration )
// This function could be more precise by using floats
// and taking into account temperature and humidity
// I used 29 microseconds per cm.
return fnDuration / 29 / 2 ;
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
