Hello,
I have a NEMA 17 stepper motor with TB6560 which is moving forward and backward between two inductive proximity switches. But i am not happy with the speed. I also want to control speed inside my code without using rotary encoder. I am attaching the code with proximity without speed control
Can someone please help me out ?
const int stepPin = 8;
const int dirPin = 9;
const int enPin = 10;
const int LimitSwitch_LEFT_Pin = 12;
const int LimitSwitch_RIGHT_Pin = 13;
pinMode(LimitSwitch_LEFT_Pin , INPUT);
pinMode(LimitSwitch_RIGHT_Pin , INPUT);
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(enPin,OUTPUT);
digitalWrite(enPin,LOW);
// Set Dir to Home switch
digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
int leftSw = digitalRead( LimitSwitch_LEFT_Pin);
int rightSw = digitalRead( LimitSwitch_RIGHT_Pin);
if( (leftSw == HIGH && (digitalRead(dirPin) == HIGH)) ||
(rightSw == HIGH && (digitalRead(dirPin) == LOW)) ){
motorStep(1);
else if( leftSw == LOW && (digitalRead(dirPin) == HIGH) ){
digitalWrite(dirPin,LOW);
delay(2000);
else if( rightSw == LOW && (digitalRead(dirPin) == LOW ) ){
delay(2000);
void motorStep( int MAX){
for(int x = 0; x < MAX; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
