With delay Code;
const int LEDPin[10] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
byte y=0;
long wait=1000;
byte SPEED_MOD=0;
void setup(){
for(y=0; y<10; y++){
pinMode(LEDPin[y], OUTPUT);
pinMode(2, INPUT_PULLUP);
pinMode(13, OUTPUT);
attachInterrupt(0, KESME, LOW);
void loop(){
digitalWrite(LEDPin[y], HIGH);
delay(wait);
digitalWrite(LEDPin[y], LOW);
void KESME(){
if(SPEED_MOD == 5){
SPEED_MOD=0;
else{
SPEED_MOD++;
if(SPEED_MOD == 0){
wait=1000;
if(SPEED_MOD == 1){
wait=700;
if(SPEED_MOD == 2){
wait=500;
if(SPEED_MOD == 3){
wait=200;
if(SPEED_MOD == 4){
wait=100;
if(SPEED_MOD == 5){
wait=50;
I want without delay code. How do I make?
The end time does not pass to the other mode.
const int noLeds = 10;
const int LEDPin[noLeds] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
unsigned long mark;
void loop(){
if(millis()>=mark){//check time mark
mark += wait;//increase time mark
digitalWrite(LEDPin[y++], 0);//turn previous led off
if(y==noLeds) y = 0;//y=y%noLeds
digitalWrite(LEDPin[y], 1);//turn next led on
}//if(millis()>=mark)
}//loop()
Not Worked
unsigned long mark;
byte y=0;
long wait=100;
byte SPEED_MOD=0;
void setup(){
void loop(){
void KESME(){
if(SPEED_MOD == 5){
SPEED_MOD=0;
else{
SPEED_MOD++;
if(SPEED_MOD == 0){
wait=10000;
if(SPEED_MOD == 1){
wait=700;
if(SPEED_MOD == 2){
wait=500;
if(SPEED_MOD == 3){
wait=200;
if(SPEED_MOD == 4){
wait=100;
if(SPEED_MOD == 5){
wait=50;
system
February 4, 2015, 7:50am
4
NOT Work
OK, define "work".
Please use code tags when posting code.
Since you are using the global y variable in the for() loop in the setup() function y will start at 10 in you code.
Robin2
February 4, 2015, 10:00am
6
veliusta:
Not Worked
So what do you think might be the problem.
Thinking is 99% of successful programming.
...R
I suggest you make y a local variable in the setup() function:
for(int y=0; y<noLeds; y++)pinMode(LEDPin[y], OUTPUT);
I did it. No Delay, No millis()
byte y=0;
long BEKLE=150000;
byte SPEED_MOD=0;
unsigned long DOGRU_ZAMAN;
unsigned long DONGU_ZAMAN;
void setup(){
y=0;
void loop(){
DOGRU_ZAMAN = DOGRU_ZAMAN+1;
if(DOGRU_ZAMAN >= (DONGU_ZAMAN + BEKLE)){
if(y==0){digitalWrite(LEDPin[9], LOW);}
digitalWrite(LEDPin[y]-1, LOW);
if(y == 9){
y=0;
}else{
y++;
DONGU_ZAMAN = DOGRU_ZAMAN;
void KESME(){
if(SPEED_MOD == 5){
SPEED_MOD=0;
else{
SPEED_MOD++;
if(SPEED_MOD == 0){
BEKLE=150000;
if(SPEED_MOD == 1){
BEKLE=75000;
if(SPEED_MOD == 2){
BEKLE=50000;
if(SPEED_MOD == 3){
BEKLE=25000;
if(SPEED_MOD == 4){
BEKLE=10000;
if(SPEED_MOD == 5){
BEKLE=5000;
You should use millis() instead, what you have done is writing your own delay which blocks the cpu and does nothing useful except that is has far worse accuracy.
