Speed controlled Knight Rider sequence issues
Hey everyone!
So for my Intro to Embedded Systems programming course I have to write a program that creates a Knight Rider sequence, but it has to have 5 different speeds that are controlled by the number of button presses. I have it almost all working, except once it hits the top 3 speeds the actual speed of the LED's does not change, rather they start to flash as they move back and forth. I have racked my brain and I can't figure out why. Any help would be much appreciated!
Thank you!
  EE1910_Lab4_ADV.ino
 Counts down from 20 to 0 in 1 second intervals,
 with a pushbutton that can reset the count to 20,
 and leds that display the status of the count.
 Author: Austin R. Bartz
 Date: 1/11/13
 Hardware connections;
 LEDs to pins 4-13
 Pushbuttons to pin 2
char LED[]={
  4,5,6,7,8,9,10,11,12,13};           //"maps" the LED pins from 0 thru 9
char button = 2;                      //variable for button pin
char lastState = 1;                   //last button state
char i;                               //variable for speed index
unsigned char t;                      //variable for delay
  char pin = 4;                         //starting pin and variable
  while(pin <= 13)                      //sets LED pins as outputs
    pinMode(pin, OUTPUT);
    ++pin;                              //increment pin #
  pinMode(2, INPUT);                    //sets button pin as input
  Serial.begin(9600);                  //starts serial
  char x = 1;                           //variable for increment
  for (char n = 0; n >= 0; n = n + x) { //loop to increment and decrement the LEDs
    char state = digitalRead(button);   //reads button state to variable
    if (state != lastState) {
      if (state == 0) i++;
    lastState = state;
    if (i == 5) i = 0;
    switch (i) {                        //sets delay and prints message based on speed index
    case 0:
      t = 200;
      Serial.println("Captain Picard says ENGAGE!");
      Serial.println("Warp 1 (SLOW)");
    case 1:
      t = 100;
      Serial.println("Warp 2 (MEDIUM)");
    case 2:
      t = 50;
      Serial.println("Warp 3 (FAST)");
    case 3:
      t = 25;
      Serial.println("Warp 4 (VERY FAST)");
    case 4:
      t = 10;
      Serial.println("Warp 5 (ULTRA FAST)");
    if (n == 0 && x == -1) t = 0;       //prevents the first LED for being ON for 2*delay
    digitalWrite(LED[n], 1);            //turns LED n ON
    if (n == 9) x = -1;                 //reverses count
    delay(t);                           //delay time
    digitalWrite(LED[n], 0);            //turns LED n OFF
Never mind, a friend helped me get it working. Apparently it was taking too long to do the serial prints and it couldn't keep up.
