I want to control the speed of a motor in the range 100 -2300 rev/min from an UNO. The power output I estimate to be up to 50 watts, but may be much less.
I currently have a PM DC geared motor that can run over this range, from a 12 volts supply, and I am driving it using the UNO PWM output.
The control algorithm is PI (no D) and this works to a fashion, but has shortcomings. The main problem is from rest and at very low revs it takes a while to start, then overshoots and stops, i.e. it oscillates.
I have tuned the PI constants manually - setting P first just below where it 'hunts', then dial in I in the same way. This works quite well at all speeds except low.
The problem seems to be that the motor drive has to overcome the static hold of the magnets, and this causes it to oscillate at low speeds.
My question is, should I keep trying to find a way to overcome this, eg using code tricks, or is it worth ditching the DC motor and trying a brushless motor having no experience of these?
Re brushless motors, if I buy one with an ESC, will this interface with the UNO? What are the comms to it (protocol and electrical)?
I want to keep the motor cost with ESC as low as possible - 10 to 15 GBP. Something like http://www.ebay.co.uk/itm/Hot-2430-7200KV-4P-Sensorless-Brushless-Motor-25A-Brushless-ESC-for-1-18-RC-Car-/131565204715?hash=item1ea1e5b4eb:g:z8EAAOSwHnFVtekj might be worth a try?
