I have tried to set up 4 speedcontrollers to use with my arduino mega, and treat them like servos. The only problem is that the speedcontrollers only respond to changes in frequency length between ~1580 and ~1604 microseconds. I need much more resolution in control than this, as I am using these motors and speed controllers for a quadrotor. Any suggestions? Things to look for? Maybe how to identify speed controllers without dampening, or how to program a larger range of response.
What brand and model of speed control are you using?
I do not know how common this is, but some ESCs had throttle range mapping during the arming procedure. When you power up the ESC, it assumes that the throttle stick is at zero throttle, and remembers this throttle location. Then you move the stick to full throttle and it remembers the high throttle signal. Then you move the throttle back to zero and the ESC them 'arms', moving from an arming mode where the motor is not powered, to flight mode where the ESC powers the motor in response to throttle commands.
If you have an ESC with some throttle mapping, then you might not be giving it wide enough throttle commands during the arming process.
This sounds crazy. You would have to post your code and a link to any datasheets for the esc for anyone to really be able to figure out what you are seeing.
OK, a quadrotor doesn't need servos. It controls its position and attitude through changing the speed of its four motors (positioned North, East, South, and West, if you will). The problem I'm having is that the speed controllers have a very small range of response. 1500 us is the zero position, the position at which they arm. However, they do not respond to any change in throttle between 1500 and ~1580. Then, between ~1580 and ~1600, the speed controllers go from no throttle to full throttle, respectively. This simply is not enough resolution to maintain stable flight. Any of you quadrotor builders out there please respond if you have encountered this, and what you did to correct it. Thanks
It really sounds to me like the esc initilization isn't being performed properly. Many (most,all?) esc have a power-up/control sequence to insure the motors don't startup at power up and than the range of control is determined before it's set to go. A link to the esc datasheet or instruction book would be a help.
The servo's zero is when the pulse width is 1.5ms. One pole is when the pulse width is 1.0ms and the other pole is when the pulse width is 2.0ms.
So you have 500us of graduation above and below 1500us. You can increment a timer to control the high time of a pulse width, down to a single microsecond. In other words, the servo should respond to a pulse width of 1750us, by turning exactly halfway towards one pole, and 1250us pulse width should turn it exaclty halfway in the other direction.
If you can't observe the functionality as described above, then your code method needs to be revisited, or you have a faulty servo.
#include <Servo.h>
Servo speedController[4];
int position = 1500;
void setup(){
for(int i = 0; i < 4; i ++){
speedController[i].attach(30 + i);
speedController[i].writeMicroseconds(1500);
void loop(){
Serial.println(position);
if(Serial.available()){
Serial.flush();
if(position == 1500){
position = 1570;
position += 1;
speedController[i].writeMicroseconds(position);
Above is my program for testing the motors.
I can control the SPEED CONTROLLERS like SERVOS because they take the same signal, but they are NOT servos. As you can see, the signal starts at 1500us, or the middle (zero). Then, it jumps quickly up to 1570 because nothing happens between 1500 and 1570. Then, after increasing it to around 1580 (by sending data to the serial port multiple times), the motors start spinning. However, the motors reach full throttle much too quickly (~1600us) and do not allow for much resolution. There are only about 20 values I can send to the motors. I hope this information helps.
I am, however, relatively new to controlling electronic components with microprocessors, and am having trouble with this. So if anyone has any ideas on how to have better control than 20 increments, it would be well appreciated.
A good question is how many discrete increments does the ESC have with the RC receiver that it is designed to work with? What is the arming and control sequence using an RC receiver, and can this effect the control band when using RC equipment? I think RC equipment only outputs the timing to move a servo from onlly +45 deg to -45 deg.
Well posting the ad for esc helps a little, but still need the arming instructions that must come with it. What ever the arming procedure is you MUST perform it with your sketch (probably best done in the setup function) before you can give valid speed commands to the esc.
The following remarks come from one of the reviewers:
I am using this esc with a turnigy 2730-1700 outrunner and it is functioning perfectly. Programming is straight forward by battery off, transmitter on, then plug in battery and move thru the throttle position slowly. Instructions would have been nice for the wiring.
Can you review the documentation that came with the esc and give us a hint on how the initilization setup for the esc is performed?
Ok, first, they are arming. They both arm and run.
Yes, they run, bit without a proper arming procedure, your ESCs might not accept the full input range.
Some ESCs map the input command range during the arming process.
When you use this ESC with your RC transmitter, you probably use a process something like this:
Tx on
throttle stick all the way down
power on ESC (some ESCs beep at this point) Wait a second or so
throttle stick all the way up. Wait a second or so.
throttle stick all the way down (some ESCs beep here)
Now the esc is armed and will respond to throttle commands.
The input that the ESC sees in steps 3 and 4 let it know what range of input commands to expect. It maps zero throttle to the input command it saw in step 3. It maps full throttle to the input command it saw in step 4.
Your sketch does not appear to have a matching arming procedure. You write 1500 for an initial value. What happens if you put your throttle stick at mid stick (1500) and power up your ESC and wait for the ESC to use just that mid stick for its arming needs? I suspect that you will find the ESC only responds to stick positions a little bit on each side of mid stick.
Try adding an arming procedure to your setup. Write a low servo command. Wait a bit. Write a high servo command. Wait a bit. Write a low servo command. You might need to play with the delays before and after to get it all to work, but you should be able to get your ESC to respond exactly as if it were connected to your RC receiver.
The other problem is that the esc most likely only enters it's initilization phase when it's first powered up. So somehow you are going to have to have your Arduino power up first but wait until you then power up the esc. Only then can you have your setup code perform whatever the proper initilizations steps are. This is not an easy task without a lot of specific information about this esc.
I checked the programming capabilities of my speed controller (HobbyCity 18A) and it can only be programmed to take either LiPo batteries, NiMH batteries, or to have a programmed break. Any suggestions?
