Hello everybody,
My plan is to serial send with an interrupt timer, the analog values which i want, the numbers of revolutions of a skate wheel and the time. The frequency of the analog send must be about 125Hz.
I'm trying to log speed using a hall detector with pin interrupt and two (or four) analog val with a Uno and a processing code on the computer, but i have some troubles.
When the wheel is turnig too fast => about 15 Hz, the interrupt send back variable compt of revolution during my wheel is turning constantly.
here my code ![]()
volatile byte revolutions;
volatile boolean flag;
unsigned long realtime;
unsigned int tension1;
unsigned int tension2;
noInterrupts(); // désactiver toutes les interruptions
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 500; // (500)16MHz/256/125Hz (fréquence d'écriture serie (echantillonage?))
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // Activer le mode de comparaison
interrupts(); // activer toutes les interruptions
//Liaison serie
Serial.begin(250000);
//gestion des interruptions
//interruption du capteur à effet hall
attachInterrupt(0, rpm_fun, FALLING);
if (flag){
//lecture des données
tension1=analogRead(A0);
tension2=analogRead(A1);
realtime=millis();
// ecriture des données
Serial.print(revolutions);
revolutions=0;
Serial.print(',');
Serial.print(tension1);
Serial.print(',');
Serial.print(tension2);
Serial.print(',');
Serial.print(realtime);
flag=false;
ISR(TIMER1_COMPA_vect){ // fonction périodique d'interruption pour ecriture sur la voie serie
flag=true;
//Interruption qui à lieu à chaque front montant sur le capteur
void rpm_fun(){
revolutions++;
Does someone have an idea?
Sorry for the French commentary and my bad English, but i'm trying to improve it ;-).
Thank you.
