Somebody pls help with arduino uno code on how to calculate speed of moving object using HCSR04 Ultrasonic Sensor.It can be a single sensor or multiple sensors.....Pls help.I need the code
If you take two distance measurements a short time apart, you just have:
distance1 - distance2 = distance speed = distance / time
You get to pick the units...
Remember, however, that common U/S sensors have very limited range, so you may only get in a couple of measurements if the target is moving fast.
The code is tested and working fine. It also includes LED blinking code.
Do make sure to insert it in the correct pin.
// defines pins numbers
const int trigPin = 9;
const int echoPin = 10;
// defines variables
long duration;
int distance1=0;
int distance2=0;
double speed=0;
int distance=0;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode( 7 , OUTPUT);
Serial.begin(9600); // Starts the serial communication
//calculating speed
distance1 = ultrasonicRead(); //calls ultrasoninicRead() function below
delay(1000);//giving a time gap of 1 sec
distance2 = ultrasonicRead(); //calls ultrasoninicRead() function below
//formula change in distance divided by change in time
speed = (distance2 - distance1)/1.0; //as the time gap is 1 sec we divide it by 1.
//Displaying speed
Serial.print("Speed in cm/s : ");
Serial.println(speed);
// LED indicator
if (distance >0 && distance <5)
digitalWrite( 7 , HIGH);
delay(50); // waits for a second
if (distance > 5 && distance <10 )
digitalWrite( 7 , LOW); // sets the LED off
if (distance >10 && distance < 20)
delay(210); // waits for a second
if (distance >20 && distance < 35)
delay(610); // waits for a second
float ultrasonicRead ()
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
//calculating distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance in cm : ");
Serial.println(distance);
return distance;
speedF.ino (2.27 KB)
Civilised_Falcon:
...but won't get you any style marks.
Civilised_Falcon:
Do make sure to insert it in the correct pin.// defines pins numbers
long duration;
int distance1=0;
int distance2=0;
double speed=0;
int distance=0;
//calculating speed
//Displaying speed
// LED indicator
return distance;
Hello, i found your code is useful!
May i know how is the hardware setup?
1 or 2 ultrasonic sensors to measure 2 distance points?
The sensor installed on side way or towards the moving vehicle?
Hello there!
In this code they have used a single ultrasonic sensor, if you want to add extra sensor just add numbers to each pin referring to the different sensors.
