Hello, can someone please advise?
I am for the school project trying to measure the speed of an object passing between 2 points.
for various reasons in the project have to ldr sensors.
My problem:
In my code 2 millis() of methods work at the same time and provide different starts but only one millis()
include function on ardiuno. Is there any other way I can do the millis transaction? or do I have any idea to solve this problem?
when the purpose is passed from the first sensor, to initiate a different millis() function after passing through the 2nd sensor. In the end to find the difference between them
you can more easily understand what I mean when you look at the code.
materials used in the project:
Arduino Genuino Uno,
2 units ldr sensor,
2 units 10k resistance
Code:
int sensor1Value;
int sensor2Value;
int average_Sensor1;
int average_Sensor2;
double startTime;
double endTime;
double distance = 15; //2 sensors between distance In cm
boolean endFlag;
average();
//Serial.println(sensor1Value); // Used for determining photoresistor thresholds
//Serial.println(sensor2Value);
Sensor1();
Sensor2();
//MoveTest();
if(endFlag == true && sensor1Value < average_Sensor1 && sensor2Value < average_Sensor2){
Calculate();
void Sensor1(){
sensor1Value = analogRead(A1);
if(sensor1Value < average_Sensor1){ // If first photoresistor passes threshold, save startTime.
startTime = millis();
endFlag = false;
void Sensor2(){
sensor2Value = analogRead(A3);
if(sensor2Value < average_Sensor2 && endFlag == false){
endTime = millis();
endFlag = true;
void Calculate(){
double Time = endTime - startTime;
double TimeInSecond = Time/1000; //millisecond yo second
double Speed = distance/(TimeInSecond);
Serial.print("Speed: ");
Serial.print(Speed);
Serial.println(" cm/s ");
Speed = (Speed*0.036);
Serial.println(" km/h \n");
void average(){
for(int i=0; i<100; i++){
average_Sensor1 += analogRead(A1);
average_Sensor2 += analogRead(A3);
average_Sensor1 = (average_Sensor1/100);
average_Sensor2 = (average_Sensor2/100);
