Hello community,
I am seeking your advice on a project I am currently working on. I love riding the road bike and I have a simple indoor trainer for training in winter or when the weather is bad. To measure the wheel speed, I wrote a python program that communicates with an Arduino via elements of the Pyduino library (GitHub - lekum/pyduino: Python library to interface with Arduino via serial connection). The wheel speed is measured using a reed contact connected to digital input 2 and ground of the arduino. The input is set on INPUT_PULLUP to prevent the pin from floating. The arduino is powered by the USB connection.
The speed measurement works perfectly fine.
Now, I want to add a fan that cools me during workout. To make things realistic, the fan is supposed to speed up with increasing wheel speed. For the fan control, I use a L298N board. The L298N is powered by a 14V DC power supply. The arduino PWM is used to control the speed of the fan.
For testing, I used a 20V DC motor of an old cordless screwdriver. After connecting everything togheter, the test worked nicely. With increasing measured wheel speed, the fan rotated faster, as intended.
Since I want to cool myself during training, I bought a small 12V DC fan. I replaced the old motor with the new fan and kept the remaining setup as it was.
Now comes the problem. From a given fan speed on, the speed measurement results in random nonsense values like 10000km/h followed by 300 km/h and again 20000km/h. When I unplug the power supply of the L298N, everything works fine again. Again, all this did not happen with the old test motor.
I have no clue where this comes from. For your information, I added the sketch of the Arduino. Please note that parts of the processing are in the python code which is not printed in my post.
I suppose that the motor current somehow influences the digital input, but I don't know how. I already use 2 separate power supplies for Arduino and L298N which I thought would prevent this kind of problem.
* Sketch to control the pins of Arduino via serial interface
* Commands implemented with examples:
* - RD13 -> Reads the Digital input at pin 13
* - RA4 - > Reads the Analog input at pin 4
* - WD13:1 -> Writes 1 (HIGH) to digital output pin 13
* - WA6:125 -> Writes 125 to analog output pin 6 (PWM)
char operation; // Holds operation (R, W, ...)
char mode; // Holds the mode (D, A)
int pin_number; // Holds the pin number
int speed_val; // Holds the pin number
int digital_value; // Holds the digital value
int analog_value; // Holds the analog value
int value_to_write; // Holds the value that we want to write
int wait_for_transmission = 15; // Delay in ms in order to receive the serial data
void set_pin_mode(int pin_number, char mode){
* Performs a pinMode() operation depending on the value of the parameter
* mode :
* - I: Sets the mode to INPUT
* - O: Sets the mode to OUTPUT
* - P: Sets the mode to INPUT_PULLUP
switch (mode){
case 'I':
pinMode(pin_number, INPUT);
case 'O':
pinMode(pin_number, OUTPUT);
case 'P':
pinMode(pin_number, INPUT_PULLUP);
void digital_write(int pin_number, int digital_value){
* Performs a digital write on pin_number with the digital_value
* The value must be 1 or 0
digitalWrite(pin_number, digital_value);
void analog_write(int pin_number, int analog_value){
* Performs an analog write on pin_number with the analog_value
* The value must be range from 0 to 255
analogWrite(pin_number, analog_value);
void write_signal() // signalizes an interrupt to the serial connection
Serial.print(2);
Serial.begin(250000); // Serial Port at 250k baud
Serial.setTimeout(1); // Instead of the default 1000ms, in order
// to speed up the Serial.parseInt() digitalWrite(in1, LOW);
pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), write_signal, FALLING); // rais interrupt when pin goes down
digital_write(8,0);
digital_write(5,1);
analog_write(9, 0);
// Check if characters available in the buffer
if (Serial.available() > 0) {
delay(wait_for_transmission); // If not delayed, second character is not correctly read
speed_val = Serial.parseInt(); // Waits for an int to be transmitted
digital_write(4,0);
digital_write(8,1);
analog_write(9, speed_val);
// Switch off if Value < 20
if (speed_val < 20){
digital_write(4,0);
digital_write(8,0);
analog_write(9, 1);
