Speed measuring device not correctly working
I use two light sensors to calculate the speed of a marble. Here's the code and CAD file:
void speedtrap() {
  speedtrap1 = millis();
  speedtraptrig = 1;
  pinMode(sensPin, INPUT_PULLUP);
  pinMode(speedpin1, INPUT_PULLUP);
  pinMode(speedpin2, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(speedpin1), speedtrap, FALLING);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0,1);
  if (speedtraptrig) {
    speedtraptrig = 0;
    unsigned long timestarted = millis();
    while (digitalRead(speedpin2)) {
      if (millis() - timestarted > speedtraptimeout) {
        Serial.println("Speedtrap sens2 Timeout!, exiting");
        return;
    speedtrap2 = millis();
    unsigned long timediffms = speedtrap2 - speedtrap1;
    float velocity = sensordist/(timediffms/10.0);
    lcd.clear();
    lcd.print("Speed: ");
    lcd.print(velocity);
    lcd.print("m/s");
    speeddisplay = 1;
The Problem is, that it only triggers 1/3 of the time, when the marble is at full speed (max. 5m/s). I can see the light of the ir detector blink, but nothing else happens. Does somebody know where the problem might be and how to fix it?
Thanls in advance
Are the variables that are updated in the ISR declared as volatile ?
It would have helped if you had posted your complete sketch (HINT)
#include <Wire.h>
#define motorPin 9
#define throttleDelay 3
#define spinupTime 100
#define sensPin 4
#define speedpin1 2
#define speedpin2 3
#define motorSpeed 200
#define motorTimeout 5000
#define sensordist 10
#define speedtraptimeout 1000
#define cols 16
#define rows 2
bool motorTrig = 0;
bool motorOn = 0;
unsigned long motorStarted;
unsigned long speedtrap1;
unsigned long speedtrap2;
bool speedtraptrig;
int speedmps;
bool speeddisplay = 0;
LiquidCrystal_I2C lcd(0x27, 16, 2);
void spinupMotor() {
  if (motorOn == 0) {
    speeddisplay = 0;
    analogWrite(motorPin, 150);
    delay(spinupTime);
    lcd.clear();
    lcd.print("Motor speed: ");
    lcd.setCursor(15,0);
    lcd.print("%");
    motorOn = 1;
    //Serial.println("motor started");
    for (int i = 150; i <= motorSpeed; i++) {
      analogWrite(motorPin, i);
      lcd.setCursor(12, 0);
      int percent = map(i, 130, 254, 000, 100);
      if (percent < 10 ) {lcd.print(0);}
      if (percent < 100 ) {lcd.print(0);}
      lcd.print(percent);
      delay(throttleDelay);
    //Serial.print("current speed:");
    //Serial.println(motorSpeed);
    motorStarted = millis();
void speedtrap() {
  speedtraptrig = 1;
  pinMode(motorPin, OUTPUT);
  pinMode(sensPin, INPUT);
  pinMode(speedpin1, INPUT);
  pinMode(speedpin2, INPUT);
  analogWrite(motorPin, 120);
  // Serial.begin(9600);
  lcd.init();
  lcd.backlight();
  lcd.print("Get");
  lcd.setCursor(0,1);
  lcd.print("Ready!!");
  if (digitalRead(sensPin) == 0 && motorOn == 0) {
    lcd.clear();
    lcd.print("Motor starting...");
    spinupMotor();
  if (millis() - motorStarted > motorTimeout && motorOn == 1) {
    //Serial.print("motor timeout ");
    //Serial.print(motorTimeout);
    //Serial.println("ms");
    if (!speeddisplay) {
    lcd.clear();
    lcd.print("Motor Timeout");
    motorOn = 0;
    speedtraptrig = 0;
        //Serial.println("Speedtrap sens2 Timeout!, exiting");
        return;
    lcd.clear();
    lcd.print("m/s");
    motorOn = 0;
    speeddisplay = 1;
Is the marble opaque?
It's a 2cm diameter stainless steel ball
Oh.
I see no lights or holes to let light through in your drawing.
It has two spots for sensors like these
And I can see they are triggering because their led blinks
Variables shared with interrupt routines MUST be declared volatile.
  speedtraptrig = 1;
When accessed in the main program, it is essential to prevent shared variables from being corrupted by an interrupt. Make a copy with the interrupts off, something like the following:
noInterrupts();
unsigned long speedtrap1_copy = speedtrap1;
interrupts();
Serial.println(speedtrap1_copy);
Okay, I'll try that, although I am not quite sure why this should help since the problem only exists when the marble has a high velocity.
Where?
Which LED?
The IR is reflecting off the curved surface (away) so is not long or strong enough to register.
Where?
My Cad drawing has to positions to mount these sensors
Which LED?
The detection LED on the sensor (lights up, when an object is detected)
Not long enough shouldn't be a problem when using interrupts, should it?
No. Your drawing shows a ramp. No IR LEDs.
That eliminates power (LED) problem.
Ok.
Time your "marble" the old fashioned way and calculate the time it spends in front of the IR transmitter. Now, use your television Remote Control and press any button for that length of time. How did your television react? Tell yourself, because I don't care. I'm not going to force you to drink the water.
Indeed, it looks like you have several problems, in addition to not taking advice.
Hi, @speeter
You have two sensors, why aren't you using two interrupts?
Tom.. :smiley: :+1: :coffee: :australia:
You should use a beam break sensor, not a retro reflective type.
Slot sensors
By any chance are your sensors arranged like this?
No.
As already mentioned at full speed it works 1/3 of the time and always at slow speed
This is the circuit
The Power supply for the Arduino normally is a Notebook. The ESC is powered by an USB PD wall brick supplying 12V
