Speed of blutooth ble on arduino Uno R4 wifi
Hello
Does someone knows the maximal speed for bluetooth on the arduino uno R4. Currently I am able to send around 17 bytes in 5 ms (using notify on other site) using writevalue.
Polling for new data takes also 5 ms (readvalue), but maybe this could be done faster using notify.
I know maybe the serial bridge between both processors may be a limiting factor, but I am able to receive data using the serial command at 230400 baud, so the speed of the bridge must be at least 230400 bps, I guess (or does this differ in arduinoBLE)
Reading the documentation, 2 Mbps should be possible (And of course I know it also depends on the other site, this is a macbook and I assume this is fast enought) Or shoudl I sned larger packages to avoid large start and stop timings?
Does anyone know where can I found technical documentation about this?
Kind regards
Jan Menssen
Tech docs are on the Arduino.cc site, under Hardware then UNO R4.
While using a larger payload does increase throughput, an error causes a bigger recovery time so it's a balancing act. Increase payload size until throughput starts to drop due to resends.
No, the information I requested is not on the site you mentioned
Hi @JanMenssen ,
I'm currently working with the UNO R4 WIFI and the ArduinoBLE library. The maximum data rate I've achieved is 6426 bytes / s using notify, sending 27 notifications of 238 bytes per second. I'm currently using the UNO R4 as peripheral and I've tried with my phone as a central device (using nRF Connect app) and my pc with a Python script using Bleak.
As the docs say a characteristic value can be up to 512 bytes long, but this seems to change when a central device subscribes to the UNO, as the MTU is reduced to 242 bytes with no possibility of changing it by a request from the central. Removing the 3-byte header leaves me with a maximum size of 239 per message, but I'm using 238 because I'm sending short uint16_t values.
I don't know if this is the normal behavior, but I would really like to have those 512 bytes per notification for the project I'm working on.
I know it's been almost a year since this discussion began, but I hope it will be helpful to someone.
