Speed of two DC motors
Hi
What is the suitable code to test the speed of two DC motors of Rover 5 (had two encoders ) ?
any answer ???
But you've got code for this haven't you? You gave results a few days ago.
What does this mean though:
had two encoders
..... Do they no longer have encoders? Have you changed the hardware?
JimboZA:
had two encoders
thanks JimboZA
that's right , I have been here since two weeks looking for convinced and final solution for my problem , actually I am completely lost , the problem is that the motors when feeding up them with same constant speed (PMW)and monitor the encoder counts , the counts of two encoders are not the same , there is a big difference . Actually I tried to use many codes for testing . I don't know where is the problem , Is it code , Is it in the hardware , I am completely lost . need for patient someone to help .
No , it is same Rover 5 with two encoders , I want to function the encoders to determine the Odomtery (X, Y , Heading ).
Post a complete program that shows this problem. Just a fixed PWM output to the 2 motors and the code to read and display the encoders values from them. An explanation of how the encoders and Arduino are wired, or better still a circuit diagram would also help.
How are the motors and Arduino powered ?
We've discussed this before: the two motors will almost certainly not run at the same speed, so why should the encoders be the same. You should accept that fact. The whole point of encoders, as already pointed out to you at the weekend, is to see the difference in motor speeds so you can speed one up or slow one down to get the vehicle moving straight. When moving straight, the pwm values will very likely differ from one side to the other, because the motors and gearboxes are different.
You posted results the other day that showed the speeds were in fact pretty close, identical in some cases.
Someone gave you an answer about those huge 20-million or whatever it was, encoder readings.
The only way to see if the encoders agree is to put both encoders on the same wheel at the same time, or at least at different times but with the same pwm value and see if the encoder readings are the same. Then when you know the encoders agree, when they are on their actual wheels you can accept their values and if one wheel goes faster than the other at same pwm, well that's the way of it. Adjust one wheel's pwm until their encoders agree, even if the pwms are then different.
UKHeliBob:
thanks UKHeliBob and JimboZA
Wires connections as follow :
L298 driver is feed up with 8 V and then I take 5 V & Ground pins of L298 driver and feed it up to Arduino mega .
ENA of L298 driver connected to Arduino's port 8
ENB of L298 driver connected to Arduino's port 9
IN1 of L298 driver connected to Arduino's port 48
IN2 of L298 driver connected to Arduino's port 49
IN3 of L298 driver connected to Arduino's port 50
IN4 of L298 driver connected to Arduino's port 51
Out1 of L298 driver connected to RightMotorWire1
Out2 of L298 driver connected to RightMotorWire2
Out3 of L298 driver connected to LeftMotorWire1
Out4 of L298 driver connected to LeftMotorWire2
LeftEncoderPinA 2 // connected to signal A of left encoder (White wire )
LeftEncoderPinB 4 // connected to signal B of left encoder (yellow wire )
RightEncoderPinA 3 // connected to signal A of right encoder (White wire )
RightEncoderPinB 5 //connected to signal B of right encoder (yellow wire )
when I test the speed of motors with code below , after feed them with 100 PWM at same time , the two speeds were almost identical , but I noticed that there is a difference between counts of two encoders even when the motors spin in the same constant speed , the difference is between 10 - 50 and increase as the two motors continue spinning as seen in the output
newposition1 = encoder1Pos;
newtime1 = millis();
vel1 = (newposition1-oldposition1) * 1000 /(long)(newtime1-oldtime1);
oldposition1 = newposition1;
oldtime1 = newtime1;
I couldn't because I used Rover 5 with encoders equipped by manufacture , it is hard to open and install them again.
the code below for that test and you could see the the speed of two motors is 100 .
#define encoder0PinA  3
#define encoder0PinB  5
#define encoder1PinA  2
#define encoder1PinB  4
int ENA=8;    // SpeedPinA connected to Arduino's port 8
int ENB=9;    // SpeedPinB connected to Arduino's port 9
int IN1=48;    // RightMotorWire1 connected to Arduino's port 48
int IN2=49;    // RightMotorWire2 connected to Arduino's port 49
int IN3=50;    // RightMotorWire1 connected to Arduino's port 48
int IN4=51;    // RightMotorWire2 connected to Arduino's port 49
volatile long encoder0Pos=0;
long newposition;
long oldposition = 0;
unsigned long newtime;
unsigned long oldtime = 0;
long vel;
volatile long encoder1Pos=0;
long newposition1;
long oldposition1 = 0;
unsigned long newtime1;
unsigned long oldtime1 = 0;
long vel1;
 pinMode(ENA,OUTPUT);
 pinMode(ENB,OUTPUT);
 pinMode(IN1,OUTPUT);
 pinMode(IN2,OUTPUT);
 pinMode(IN3,OUTPUT);
 pinMode(IN4,OUTPUT);
 digitalWrite(ENA,HIGH);    //enable motorA
 digitalWrite(ENB,HIGH);    //enable motorB
  pinMode(encoder0PinA, INPUT);
  digitalWrite(encoder0PinA, HIGH);       // turn on pullup resistor
  pinMode(encoder0PinB, INPUT);
  digitalWrite(encoder0PinB, HIGH);       // turn on pullup resistor
  attachInterrupt(1 ,doEncoder, RISING);  // encoDER ON PIN 2
  pinMode(encoder1PinA, INPUT);
  digitalWrite(encoder1PinA, HIGH);       // turn on pullup resistor
  pinMode(encoder1PinB, INPUT);
  digitalWrite(encoder1PinB, HIGH);       // turn on pullup resistor
  attachInterrupt(0, doEncoder1, RISING);  // encoDER ON PIN 2
  Serial.begin (9600);
int WR=100;  // angular velocity of right wheel
int WL=100;  // angular velocity of right wheel
    int rightPWM;
  if (WR > 0) {
    //forward
  digitalWrite(IN1,LOW);
  digitalWrite(IN2,HIGH);
  }  else if (WR < 0){
    //reverse
  digitalWrite(IN1,HIGH);
  digitalWrite(IN2,LOW);
  if (WR == 0) {
   rightPWM = 0;
   analogWrite(ENA, rightPWM);
    rightPWM=WR;
 int leftPWM;
  if (WL > 0) {
     //forward
  digitalWrite(IN3,LOW);
  digitalWrite(IN4,HIGH);
  }  else if (WL < 0) {
     //reverse
  digitalWrite(IN3,HIGH);
  digitalWrite(IN4,LOW);}
  if (WL == 0) {
    leftPWM = 0;
    analogWrite(ENB, leftPWM);
    leftPWM=WL;
 newposition = encoder0Pos;
 newtime = millis();
 vel = (newposition-oldposition) * 1000 /(long)(newtime-oldtime);
 Serial.print (vel*-1);
Serial.print ("\t\t");
 oldposition = newposition;
 oldtime = newtime;
 Serial.print (vel1);
 Serial.print(abs(vel)-abs(vel1));
Serial.print(encoder0Pos*-1);
Serial.print(encoder1Pos);
Serial.println(abs(encoder0Pos) - abs(encoder1Pos));
 delay(250);
void doEncoder()
  if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB)) {
    encoder0Pos++;
    encoder0Pos--;
void doEncoder1()
  if (digitalRead(encoder1PinA) == digitalRead(encoder1PinB)) {
    encoder1Pos++;
    encoder1Pos--;
the output
56		59		-3		14		15		-1
87		87		0		36		38		-2
96		95		1		60		61		-1
95		96		-1		84		85		-1
95		95		0		109		109		0
95		95		0		132		133		-1
95		91		4		156		156		0
99		95		4		181		180		1
99		95		4		206		204		2
95		91		4		230		227		3
99		99		0		255		252		3
100		100		0		280		277		3
99		91		8		305		300		4
91		95		-4		328		324		4
95		95		0		352		348		4
91		95		-4		375		372		3
91		95		-4		398		396		2
91		91		0		421		419		2
95		91		4		445		442		3
96		96		0		469		466		3
99		95		4		494		490		4
95		99		-4		518		515		3
99		95		4		543		539		4
95		107		-12		568		566		2
95		95		0		591		590		1
95		99		-4		615		615		0
95		107		-12		639		642		-3
95		99		-4		663		667		-4
96		96		0		687		691		-4
99		95		4		712		715		-3
91		99		-8		735		740		-5
99		99		0		760		765		-5
95		91		4		784		788		-4
95		103		-8		808		814		-6
95		91		4		832		838		-6
99		95		4		1330		1334		-4
95		95		0		1354		1358		-4
99		95		4		1379		1382		-3
91		95		-4		1402		1406		-4
99		103		-4		1427		1432		-5
91		95		-4		1450		1456		-6
91		95		-4		1473		1480		-7
96		95		1		1497		1504		-7
95		99		-4		1521		1529		-8
91		95		-4		1544		1553		-9
103		95		8		1570		1577		-7
95		95		0		1594		1601		-7
99		95		4		1619		1625		-6
99		95		4		1644		1649		-5
95		95		0		1668		1674		-6
87		95		-8		2362		2369		-7
99		95		4		2387		2392		-6
91		99		-8		2410		2417		-7
95		95		0		2434		2441		-7
95		95		0		2458		2465		-7
95		95		0		2482		2489		-7
95		95		0		2506		2513		-7
96		92		4		2530		2536		-6
87		95		-8		2552		2560		-8
95		95		0		2576		2584		-8
95		95		0		2601		2608		-7
99		103		-4		2625		2634		-9
100		103		-3		3563		3596		-33
95		96		-1		3587		3621		-34
91		107		-16		3610		3647		-37
95		91		4		3634		3670		-37
99		99		0		3659		3695		-36
95		99		-4		3683		3720		-37
87		95		-8		3705		3744		-39
99		103		-4		3730		3770		-40
99		99		0		3755		3795		-40
96		95		1		3779		3819		-40
95		95		0		3803		3843		-40
95		99		-4		3827		3868		-41
95		95		0		3851		3892		-41
91		99		-8		3874		3917		-43
99		95		4		3899		3941		-42
99		99		0		3924		3966		-42
99		99		0		3949		3992		-43
99		99		0		3974		4016		-42
96		100		-4		3999		4041		-42
99		95		4		4023		4065		-42
95		95		0		4047		4089		-42
99		99		0		4072		4114		-42
95		79		16		6714		6792		-78
100		112		-12		6739		6820		-81
87		83		4		6761		6841		-80
95		95		0		6785		6865		-80
95		87		8		6809		6887		-78
95		95		0		6833		6911		-78
75		75		0		6852		6930		-78
27		19		8		6859		6935		-76
The fact that the encoder counts are different for each wheel would seem to indicate that the motors are not running at the same constant speed, but that is nothing to worry about and for cheap DC motors is to be expected.
When you feed a signal with the same PWM value to both motors does the robot run straight ? I would be amazed if it did. The solution is to count the encoder signals for a period of time and to adjust the speed of the motors to slow the fast one and speed up the slow one then start the count again and adjust again after a period of time and so on. The smart way to do this is to use a PID to sense the difference between the encoder counts and adjust the motor speeds accordingly,
UKHeliBob:
thanks a lot UKHeliBob
I can almost say Yes .
but if monitor the output you could see that the speed of two wheel almost the same .
95 99 -4 663 667 -4
**96 96 ** 0 687 691 -4
99 95 4 712 715 -3
91 99 -8 735 740 -5
**99 99 ** 0 760 765 -5
95 91 4 784 788 -4
95 91 4 832 838 -6
Actually , I have questions need to some explanation .
The code below , is it the right way to determine the speed of motor by encoders ?
so is there any posts or tutorial could help me in that way ?
thanks
:blush: waiting for any answer :blush:
My advice would be to stay away from PIDs to start with and use the crude method because you will have full control over what is going on.
Some pseudo code for you
declare global variables
setup() function
   usual stuff to set up pinModes and interrupts
loop() function
  if it is time to adjust speeds (use the BlinkWithoutDelay principle using millis())
    if the left encoder count is higher than the right encoder count
      speed up the right motor a small amount
      slow down the left motor a small amount
    end if
    if the right encoder count is higher than the left encoder count
      speed up the left motor a small amount
      slow down the right motor a small amount
    end if
    zero both encoder counts
    reset the timing variables
  end if
end of loop function
left encoder ISR
  add 1 to left encoder count
end of function
right encoder ISR
  add 1 to right encoder count
end of function
If you want to explore the use of a PID then this page will get you started but it can be hard going Arduino Playground - HomePage
UKHeliBob:
setup() function
loop() function
    end if
    end if
  end if
left encoder ISR
end of function
right encoder ISR
end of function
If you want to explore the use of a PID then this page will get you started but it can be hard going http://playground.arduino.cc/Code/PIDLibrary
thanks a lot
but could I considered that the code below , it is the right code to determine the speed of motor by encoders ?
I am again… !
Encoders problem again…!
Odometery problem again…!
Actually , I have been since two weeks looking for convinced and final solution for my problem , actually I am completely lost , the members here I think they know about my problem since I post here many times but no problem to remember again , I am working on mobile robot (Rover 5) with 2 motors , 2 encoders . the controller that designed to the robot needs to know the odometery of mobile robot (X ,Y, Heading Angle ) , actually I am trying to function the encoders for this purpose , getting X ,Y, Heading Angle by measuring the traveled distance by each wheel , so to get the X ,Y, Heading Angle values , I should compute a accurate readings without missing any counts or ticks as could as possible .
The problem now is : In the code below , while I am testing the encoders counts , I noticed that odometry results computed by code are wrong and not identical the value on real world where robot is located .
In the test code the speed of right and left motors are feed up 50 PWM & 100 PWM respectively and at same time , but when I solve the odometry equations manually and compare results with code results , the two results are not identical , for example , lets take the output line
Left Encoder= 27 Right Encoder= 15 X= 0.01 Y= 0.03 Heading= 56.22
deltaHeading = (double)(deltaRight - deltaLeft) / TrackWidth;
= ( 15 - 27 ) /0.189
= -63.4920
Left Encoder= 705 Right Encoder= 571 X= -0.17 Y= -0.09 Heading= 531.41
= ( 571 - 705 ) / 0.189
= -708.99
Actually , I don't know where is the problem , Is it in the code ? Is it in the hardware ? or what ?
the code below and the output of code in the attachments
#define encoder0PinA 2
#define encoder0PinB 4
#define encoder1PinA 3
#define encoder1PinB 5
#define PI 3.14159265
#define TwoPI 6.28318531
volatile int LeftEncoderCounts = 0;
volatile int RightEncoderCounts = 0;
int WR=50;  // angular velocity of right wheel
    double _DistancePerCount;
    double _radiansPerCount;
    //long _leftEncoderCounts;
    long _PreviousLeftEncoderCounts;
   // long _RightEncoderCounts;
    long _PreviousRightEncoderCounts;
        double X;  // x coord in global frame
        double Y;  // y coord in global frame
        double Heading;  // heading (radians) in the global frame. The value lies in (-PI, PI]
        double WheelDiameter;
                double TrackWidth;
                double CountsPerRevolution;
                double DistancePerCount;
                double RadiansPerCount;
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
                        WheelDiameter = 0.062;
                        TrackWidth = 0.189;
                        CountsPerRevolution = 83;
                        DistancePerCount = (PI * WheelDiameter) / (double)CountsPerRevolution;
                        RadiansPerCount = DistancePerCount / TrackWidth;
void loop(){ //Do stuff here
    int rightPWM;
  if (WR > 0) {
    //forward
  }  else if (WR < 0){
    //reverse
  if (WR == 0) {
   rightPWM = 0;
    rightPWM = map(abs(WR), 1, 100, 1, 255);
   // rightPWM=WR;
 int leftPWM;
  if (WL > 0) {
     //forward
     //reverse
  if (WL == 0) {
    leftPWM = 0;
    leftPWM = map(abs(WL), 1, 100, 1, 255);
    //leftPWM=WL;
 long deltaLeft = LeftEncoderCounts - _PreviousLeftEncoderCounts;
 long deltaRight = RightEncoderCounts - _PreviousRightEncoderCounts;
                double deltaDistance = 0.5f * (double)(deltaLeft + deltaRight) * DistancePerCount;
                double deltaX = deltaDistance * (double)cos(Heading);
                double deltaY = deltaDistance * (double)sin(Heading);
                double deltaHeading = (double)(deltaRight - deltaLeft) / TrackWidth;
                X += deltaX;
                Y += deltaY;
                Heading += deltaHeading;
                if (Heading > PI)
                        Heading -= TwoPI;
                        if (Heading <= -PI)
                                Heading += TwoPI;
                _PreviousLeftEncoderCounts = LeftEncoderCounts;
                _PreviousRightEncoderCounts =RightEncoderCounts;
Serial.print("Left Encoder= ");
Serial.print(LeftEncoderCounts*-1);
Serial.print("\t\t");
Serial.print("Right Encoder= ");
Serial.print (RightEncoderCounts*-1);
Serial.print("X= ");
Serial.print(X);
Serial.print("Y= ");
Serial.print(Y);
Serial.print("Heading= ");
Serial.println(Heading);
void doEncoderA(){
  // look for a low-to-high on channel A
  if (digitalRead(encoder0PinA) == HIGH) {
    // check channel B to see which way encoder is turning
    if (digitalRead(encoder0PinB) == LOW) {
      LeftEncoderCounts = LeftEncoderCounts + 1;         // CW
    else {
      LeftEncoderCounts = LeftEncoderCounts - 1;         // CCW
  else   // must be a high-to-low edge on channel A
    if (digitalRead(encoder0PinB) == HIGH) {
    else {
void doEncoderB(){
  // look for a low-to-high on channel B
  if (digitalRead(encoder1PinB) == HIGH) {
   // check channel A to see which way encoder is turning
    if (digitalRead(encoder1PinA) == HIGH) {
      RightEncoderCounts = RightEncoderCounts + 1;         // CW
    else {
      RightEncoderCounts = RightEncoderCounts- 1;         // CCW
  // Look for a high-to-low on channel B
  else {
    if (digitalRead(encoder1PinA) == LOW) {
    else {
      RightEncoderCounts = RightEncoderCounts - 1;          // CCW
Output_of_the_code.ino (4.43 KB)
Maria88:
Post link(s) to the earlier Thread(s) so we have all the background info.
...R
Robin2:
Maria88:
...R
thanks Robin2
I thinks the current post where we are is enough to show the problem and if there any questions I will be here to answer .
thanks
Maria88:
It looks like someone has merged the Threads so I don't have to disagree with you :slight_smile:
I don't understand what you mean by this
deltaHeading = (double)(deltaRight - deltaLeft) * TrackWidth;
= ( 15 - 27 ) * 0.189
= -63.4920
The answer should be -2.268 but when I look in your code the formula divides by Trackwidth hence -63.492. Which is correct?
Can you provide an overview of where you are with your project at this stage?
Earlier you seemed to be having trouble with relating the encoder counts and the PWM settings. Has that now been resolved?
The reason I ask is that there seems little point in discussing how the encoder counts should be processed unless you are satisfied that the counting is correct.
Are all these complicated formula really necessary? If you want the robot to go straight you just need to adjust the speeds to get the encoder counts to stay the same, or nearly the same. I imagine that turns could also be worked out with simple integer maths. Unless you are relating the movement of the robot to an external reference (GPS or compass) the apparent accuracy of cosines to three decimal places is unlikely to have any connection with reality. The same goes for wheel diameter unless the two wheels have different diameters - even then a simple correction should be sufficient.
...R
