Hi Everyone,
I am trying to sample some sinousidl signals of range 1Hz to 1KHz. With the current code i am not getting good samples. Can someone suggest me a way to increase the sampling rate so that i can sample the higher frequency with more resolution. I know the fact that analogRead takes about 0.1ms and digital write takes about 2us for complete execution. I tried to time my whole loop and it takes about 1ms for the whole loop to complete which is pretty slow. May be someone can suggest me a method to increase this sampling speed so that my loop;loops faster.
const int numReadings = 4;
int readings[numReadings]; // the readings from the analog input
int index = 0;// the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int average_new=0;
int average_final=0;
int inputPin = A0;
unsigned long time;
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
// initialize serial communication with computer:
// initialize all the readings to 0:
//initialise the array here.
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
time=micros();
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
//first time to the loop, we set the index value of zero to the reading.
readings[index] = analogRead(inputPin);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// so that we stay in the array
average = total / numReadings;
int myMaxValue = readings[index];
int size=numReadings;
for (int i=0; i<size; i++) {
myMaxValue= max (myMaxValue, readings[i]);
if (average <0 )
digitalWrite(1, HIGH);
digitalWrite(1, LOW);
if (average <200 && average >1)
digitalWrite(2, HIGH);
digitalWrite(2, LOW);
if (average <300 && average >200 )
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
if (average <400 && average >300 )
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
if (average <500 && average >400 )
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
if (average <600 && average >500 )
digitalWrite(6, HIGH);
digitalWrite(6, LOW);
if (average <700 && average >600 )
digitalWrite(7, HIGH);
digitalWrite(7, LOW);
if (average <800 && average >700 )
digitalWrite(8, HIGH);
digitalWrite(8, LOW);
if (average <900 && average >800 )
digitalWrite(9, HIGH);
digitalWrite(9, LOW);
if (average <1023 && average >900 )
digitalWrite(10, HIGH);
digitalWrite(10, LOW);
Serial.print (readings[index]);
Serial.print("\t");
Serial.print(average);
Serial.print("\t");
Serial.print(myMaxValue);
Serial.print ("\t");
Serial.print(time);
