I’m pretty new to arduino, and need a little help with a problem I have. So basically I have a 1958 Edsel that has a speed warning light in the speedometer that illuminates when you exceed a certain speed set by a dial just below it. However, the original mechanical setup is long gone and decided to use a VSS speed sensor and an arduino to make the system work again. I have the code about 80% done, but I’m having an issue aligning the speed numbers on the dial with what the arduino is reading at that speed. I have the upper and lower numbers correctly “aligned”. The gaps in between each 5 mph mark get bigger as they go up the dial, causing the middle numbers to be way off, and was wondering how to correctly map the numbers? I’m by no means an arduino whiz, so any help would be appreciated!
(Link to image of selector dial)
https://drive.google.com/file/d/1Y-9kqM0OU5dZNhHJX47VrNrB9qs3AqxW/view?usp=drivesdk
