Speeding up base64 encoding from SD card to ethernet
I am trying to do the following:
  1. read a file from an Sd card
  2. base64 Encode it on the fly.
  3. use Client.write() to send it to an email address using SMTP commands.
i was able to do this using the below code:
  int clientCount = 0;
  myFile = SD.open("picture2.jpg");
  if (myFile) {
      encode();
void encodeblock(unsigned char in[3], unsigned char out[4], int len) {
  out[0] = cb64[in[0] >> 2]; out[1] = cb64[((in[0] & 0x03) << 4) | ((in[1] & 0xF0) >> 4)];
  out[2] = (unsigned char) (len > 1 ? cb64[((in[1] & 0x0F) << 2) | ((in[2] & 0xC0) >> 6)] : '=');
  out[3] = (unsigned char) (len > 2 ? cb64[in[2] & 0x3F] : '=');
void encode() {
  unsigned char in[3], out[4]; int i, len, blocksout = 0;
  while (myFile.available() != 0) {
    len = 0; for (i = 0; i < 3; i++) {
      in[i] = (unsigned char) myFile.read();
      if (myFile.available() != 0) len++;
      else in[i] = 0;
    if (len) {
      encodeblock(in, out, len);
      for (i = 0; i < 4; i++) client.write(out[i]);
      blocksout++;
    if (blocksout >= 19 || myFile.available() == 0) {
      if (blocksout) client.print("\r\n");
      blocksout = 0;
This however takes quite some time because the code reads byte by byte from the SD card.
Then i found this:
  if (myFile) {
    while (myFile.available()) {
      clientCount = myFile.read(tBuf, 64);
      client.write((byte*)tBuf, clientCount);
    myFile.close();
This function is much faster as it reads from card and writes to buffer.
My question is how can I combine this with the encode function?
Currently, the encode function reads every single byte from the Sd card decoded, goes back and repeats till it reaches the end.
I want the encode function to read from buffer instead to speed things up.
Any help will be much appreciated.
Since the conversion is done three bytes at a time you should probably make your buffer a multiple of three bytes. I don't know what you are supposed to do if your file is not a multiple of three bytes in length.
johnwasser:
Normally it is padded with zero's
robtillaart:
That would create ambiguity since one would not be able to tell the difference between terminal real zeros and padded zeros. The Base64 spec (see Base64 - Wikipedia) converts each 3 bytes to 4 bytes with the last block of 4 bytes being xxxx, xx== or xxx= (x being a base 64 character). This removes the ambiguity.
You're right it's padding with = chars!
