Speeding Up matrix computation
Hi everyone,
I am trying to learn to produce more efficient and faster computations in Arduino.
I am performing a maths equation with two 13x13 Matrix that takes around 400 us to compute. I had the idea to maybe use the cache for faster access to the matrix's that i saved as global int Array's but wasn't really sure how to go about it.
Can you recommend places to go or further ideas to achieve faster operation.
Z
Serial.begin(57600);
  int A[13][13] = {
  {106,62,69,74,8,91,97,6,114,86,45,48,34},
  {72,49,100,34,69,7,33,21,23,10,71,33,26},
  {85,120,57,101,65,59,63,104,94,75,54,107,43},
  {19,25,89,100,3,27,10,91,32,36,86,26,94},
  {100,31,87,111,39,89,66,6,123,46,84,30,73},
  {18,38,108,60,37,17,76,98,68,71,40,116,79},
  {38,9,112,81,14,106,61,67,4,29,94,57,106},
  {40,17,29,122,98,52,7,15,58,93,124,4,16},
  {101,23,13,94,124,107,84,21,46,80,66,98,48},
  {37,80,44,27,124,49,118,83,43,3,123,15,126},
  {87,79,41,126,60,97,35,13,113,31,93,32,118},
  {23,118,69,55,75,95,118,59,50,34,99,11,101},
  {72,115,5,26,95,28,96,10,113,112,39,119,22}
  int B[13][13] = {
    {84,67,47,117,51,34,100,80,91,1,87,107,69},
    {116,90,91,57,85,39,45,83,56,108,6,66,72},
    {101,5,118,66,89,100,20,123,67,67,16,97,16},
    {0,68,73,108,93,96,78,93,46,21,69,4,53},
    {126,26,63,35,52,55,126,124,93,41,7,57,33},
    {54,9,8,36,48,48,109,103,101,39,1,52,10},
    {102,99,94,107,80,127,73,126,122,32,19,113,13},
    {6,82,30,99,52,119,59,89,92,83,22,84,127},
    {110,113,105,96,82,116,123,67,110,73,20,35,55},
    {30,80,110,14,33,90,25,27,122,119,11,8,28},
    {47,67,61,71,92,5,17,29,83,51,73,97,37},
    {38,67,25,46,26,93,9,18,87,46,65,1,110},
    {0,95,18,99,31,68,30,43,53,71,31,109,49}
int C[13][13];
uint32_t START = micros();
    for (int i = 0; i < 13; i++)//rows
           for (int j = 0; j < 13; j++)//coloumns
               C[i][j] = (((A[i][j])*(B[i][j]))+(2*(A[i][j])));  //this is the computation that I would like to
        //make more efficient
  uint32_t END = micros();
  uint32_t result = END - START;
  Serial.print("Time taken for computation of (A*B)+(2*A) = ");
  Serial.print(result); Serial.print(" us\nResult:\n");
               Serial.print(C[i][j]); Serial.print(" ");
               //Serial.print(i); Serial.print(j); Serial.print("  ");
  delay(3000);
  exit(0);
(deleted)
Please read this and place your code inside tags.
What cache?
This
C[i][j] = (((A[i][j])-(B[i][j]))+(2*(A[i][j])));  //this is the computation that I would like to
is equivalent to
C[i][j] = 3*A[i][j] - B[i][j];
but the compiler may have already figured that out for you. It is quite "smart".
The equation disagrees with the printed comment:
Why are you using 2D arrays for a point by point, 1D computation?
whoops, it should of been this to match the text equation.
jremington:
jremington:
I'm not sure i understand. But my idea was to cycle through the matrix for each point so that the computation would be faster.
I wonder if pointer math and a single loop would be faster than array math and a double loop:
  int *c = &C[0][0];
  int *a = &A[0][0];
  int *b = &B[0][0];
  for (int i = 0; i < 13 * 13; i++) // All array elements
    *c = (*a * *b) + (2 * *a);
    c++;
    a++;
    b++;
I have been questioning if its the maths (or at least make the maths as efficient as possible), or how easy it is to try and change how quickly the memory is accessed and stored. Any ideas?
johnwasser:
So I gave it a try and compared the results, apparently using your method is faster measuring at (312 us, from the previous 464 us). Which is a pretty impressive boost.
Next thing I would try is to declare A and B as const uint8_t. All of the values are below 255 and this might save on fetch time. Be sure to change the 'a' and 'b' pointers to match or the answers will be WAY off.
const uint8_t A[13][13] =
  {106, 62, 69, 74, 8, 91, 97, 6, 114, 86, 45, 48, 34},
  {72, 49, 100, 34, 69, 7, 33, 21, 23, 10, 71, 33, 26},
  {85, 120, 57, 101, 65, 59, 63, 104, 94, 75, 54, 107, 43},
  {19, 25, 89, 100, 3, 27, 10, 91, 32, 36, 86, 26, 94},
  {100, 31, 87, 111, 39, 89, 66, 6, 123, 46, 84, 30, 73},
  {18, 38, 108, 60, 37, 17, 76, 98, 68, 71, 40, 116, 79},
  {38, 9, 112, 81, 14, 106, 61, 67, 4, 29, 94, 57, 106},
  {40, 17, 29, 122, 98, 52, 7, 15, 58, 93, 124, 4, 16},
  {101, 23, 13, 94, 124, 107, 84, 21, 46, 80, 66, 98, 48},
  {37, 80, 44, 27, 124, 49, 118, 83, 43, 3, 123, 15, 126},
  {87, 79, 41, 126, 60, 97, 35, 13, 113, 31, 93, 32, 118},
  {23, 118, 69, 55, 75, 95, 118, 59, 50, 34, 99, 11, 101},
  {72, 115, 5, 26, 95, 28, 96, 10, 113, 112, 39, 119, 22}
const uint8_t  B[13][13] =
  {84, 67, 47, 117, 51, 34, 100, 80, 91, 1, 87, 107, 69},
  {116, 90, 91, 57, 85, 39, 45, 83, 56, 108, 6, 66, 72},
  {101, 5, 118, 66, 89, 100, 20, 123, 67, 67, 16, 97, 16},
  {0, 68, 73, 108, 93, 96, 78, 93, 46, 21, 69, 4, 53},
  {126, 26, 63, 35, 52, 55, 126, 124, 93, 41, 7, 57, 33},
  {54, 9, 8, 36, 48, 48, 109, 103, 101, 39, 1, 52, 10},
  {102, 99, 94, 107, 80, 127, 73, 126, 122, 32, 19, 113, 13},
  {6, 82, 30, 99, 52, 119, 59, 89, 92, 83, 22, 84, 127},
  {110, 113, 105, 96, 82, 116, 123, 67, 110, 73, 20, 35, 55},
  {30, 80, 110, 14, 33, 90, 25, 27, 122, 119, 11, 8, 28},
  {47, 67, 61, 71, 92, 5, 17, 29, 83, 51, 73, 97, 37},
  {38, 67, 25, 46, 26, 93, 9, 18, 87, 46, 65, 1, 110},
  {0, 95, 18, 99, 31, 68, 30, 43, 53, 71, 31, 109, 49}
int C[13][13];
  int *c = &C[0][0];
  const uint8_t * a = &A[0][0];
  const uint8_t * b = &B[0][0];
  for (int i = 0; i < 13 * 13; i++) //rows
    c++;
    a++;
    b++;
  delay(3000);
  exit(0);
johnwasser:
You are a genius! It has gone down to 248 us. This is really interesting to explore, I am trying to become a better programmer and its fascinating to know that is now almost 2x more efficient.
